All you need is a working vesc/esc to use swd. Really easy. Working unit has to have I think fw3.58 and above.
These are the only two I have, and theyre both 3.24
Would 1 Samsung 18650-22F need a BMS (for a remote mod) ? I am wondering if I could slap one of these behind a dead boosted board board remote that Iāll gut out tome make an arduino remote out of it
Most likely, you need some kind of thing to take the voltage and bump or drop it to a consistent feed and start/stop charging. Although some arduino boards actually have this built in already.
Unfortunately 0.80 works for 2.27ā¦
so so close >:(
You can buy single battery PCM boards with undervoltage, overvoltage and overcurrent protection for $2usd on AliExpress but donāt expect them until 2023 at this rate.
Thats probably better than what I was thinking since it has a microUSB port, good find.
Edit: And input/output LEDS damn!
For litteraly 1 cent, I dont even know how this is profitable for them
They donāt pay me to ask questions.
12s is like turbo for your board bro. everything about it is just faster, more torque, runs cooler, gives more range, makes the board lighter, uses less power, boosts your stock portfoliosā¦
err bump?
Yes, mixed success.
Higher S count can definitely have an effect on temperature, but Iād say it is a combination of things. For the same power (watts), double the voltage means half the amps, which means half the heat in the wiring. It doesnāt quite work like that in the ESC though. The unity does have a bigger heatsink which contributes a lot to that difference. Battery settings on the unity is also for both motors, not single.
Anyone know if the savant baseplates are the same shape as the regular paris baseplates?
This probably a dumb ass questionsā¦ can we put hypertrucks on non trampa/prototipo/etc deck??
Say a redember44 or evo or something along those lines.
With wedges or adjustable baseplates sure.
wouldnāt the mounting truck it comes with not be compatible with most adjustable baseplatesā¦?
No, base plates are specific to certain trucks. I very much doubt there is an adjustable baseplate available for the hypertrucks.
@NoWind makes one for the MBS Matrix II trucks tho.
Thank you that makes sense. I guess I could use something like:
https://shop.3dservisas.eu/products/fatboy-35%C2%BA-riser-adapter-for-trampa-mbs-longboard-trucks
You certainly could
