Do you measure the entire length of a bolt or just the length of the threading?
It’s either ~18mm or ~23mm :thinking:
Hardware in question:
E nevermind xd I’m dumb
just the thread length
only the threaded part.
m3 x 10mm = 10mm usable bolt length
edit : if you have these i’d measure the blank and threaded part.
When I’m in the slave with the metr module, it works fine, and expert mode looks good, like this:
and how does it look on the master? (or is this already master) and just real time won’t work?
it varies by fastenr but as you and others have stated in this case its the thread length. you can also use the nominal length.
The nominal length of a screw is the length or size which is used to define the length of the fastener, it is the name of the screw size, and not necessarily the overall length of the component. Nominal lengths are usually found within product names or catalogue listings - they are simplified terms used to refer to a screw when literal sizes or micron-accurate measurements would be inconvenient. Nominal length differs from length in that ‘length’ is a vague term which could refer to several different dimensions, whereas ‘nominal length’ is more specific
https://www.accu.co.uk/en/p/133-how-to-measure-the-length-of-a-screw
For fuck sake … think I found it
That was configured just as PPM
in your example these are called shoulder bolts. the “blank” bit is the shoulder
https://www.accu.co.uk/10-shoulder-screws
I guess I’ll go the hardware store instead of trying to order them online, and I’ll just bring one to compare :thinking:
Thank you @Mainflow, @xsynatic and @wandagoner :pray:
@Robert-Jan
have you read through Mike’s
this may help fill in some gaps for you
Yup, did the same. Got confused by some companies using metric and some imperial. Went to the store and was done.
look I have bolts everywhere
Am i the only one that gets a slight headache after a long ride? (I assume it comes from the wind or the alway turned head?)
100%(use the eyes :wink:)
need to get some bearings. 12x28mm for mbs fivestar. Is there a brand to look for? NSK?
what are all the different variations like 6203 or 6204?
:grin:
6001-2RS
12x28x8mm
The bearing is common enough to get it from a name brand at a reasonable cost
How big a difference can 12s vs 10s mean for ESC temperatures?
45c vs 80c difference?
I can overheat a Lacroix DSS50+ going up hills. I’m 215lbs. board is dual focbox, 35 max battery amps each. 10s5p sanyo 20700b. Temps get from ambient 24c. to 80c quick. same on two of the same board.
I rode a Lacroix nazare up those same and still steeper hills. focbox unity, 45 max battery amps, 12s6p sanyo 20700b temps got up 50c. a huge difference.
can 12s make that difference? is it the unity? does it run cooler than the og focboxes by a lot? something else?
EDIT. actually now that I wrote it out… one system can draw 70amps from the pack, and the other only 45? that would certainly make things run cooler … maybe i have something wrong in my numbers here. or maybe that 45amps on the unity is per motor… 90 battery amps?
I probably going to buy the Meepo V3
It has a range on 11 miles/18km
Top speed is 45kph/28mph
And it cost $380.
Just a little worried about the torque.
I was just wondering if I could build something better for the same price or little bit more. Budget: $500.
does anybody know who’s got the world record for fastest esk8 now? @MoeStooge? any video?
