If I don’t miss my guess, that’s the sound of a can resonating as its magnets brush against the stator. It’s a combination of natural resonance and a slight imbalance.
another reason to own one of these i guess
totally worth the 5€
ps: how anyone is able to remove motor pulleys without torch is beyond me
Disassemble the bearing, then remove it and put in a new bearing
practice disassembling on a spare bearing so you can see how they come apart
Hello I’m still in doubt …
Is this correct?! I have Maytech superfoc, see picture
And flipsky remote
So I take the standard wire that is already on the esc, so my UART ports will stay available for Bluetooth and davega
Other problem was. My davega and my flipsky remote have both 8 pin cable. But my esc has 7 pin UART
Yep thats pin 8 adc 3 only found on newer ver 6 vesc. Its not required for either of those applications.
Can someone explain if I did it right. The two pins not used on the reciever are pins :
- vtx
- vrx
Don’t know what they are
The receirer has a ppm and uart mode, in ppm Mode the rx and tx pins are not connected. As they are uart only
I have two davega sitting on the self. they never make the uart vote on my boards. Bluetooth and uart remote or pixel controller always win.
Could you help and explain the best way to take apart the bearing
I removed the rubber seal and have no idea what to do next
I had sand in my big balls i removed the seal tried to pull them apart but settled on soaking them in petrol for 24 hours and some toothbrush work before soaking my big balls in speed cream.
Watched some video will try to do it again now
Thanks
So I tried removing the bearing and all worked well on the practise one but when I tried on the stuck bearing the retainer ring which holds the balls would not budge please somebody help
can you make a pic?
JUST GET NEW BEARINGS
honestly though, force a bit, this isn’t micro surgery. push the retainer as hard as you can with your flat screw bit
Tried pushing as hard as I can but it won’t come out
I will happily replace the bearing but need to get the old one out first
yes i see the pic now, it does seem stuck lol. Is that bearing in a motor?
