FOC mode is slower and less powerful but more efficient and quiet. A safe bet is it would increase your range 1% or maybe 2% at the same riding speed.
Thatās the best and shortest answer youāve ever given. Cheers!
I took away your like because shartis edited his post to extend its length
Why you ruin? WHY?
iām not known for brevity.
Because āprofessorā not āmrā
They donāt have 210kV apparently right now. And only have 190kV in stock and I can order the 220kV which takes approx 30 days. What do you recommend? For the thorium. Thanks in advance.
What do you need them for?
Iāve recently seen somewhat circumstantial evidence that going above around 190kv doesnāt really bring much benefit because although with proper gearing it can reduce the copper losses, above around 5-6k rpm the iron losses can exceed the copper losses and increase exponentially⦠so assuming you gear accordingly, a low resistance 190kv should be just as good if not better than a same size 210kv with the same copper fill, performance and efficiency wiseā¦
a 190kv motor at 50v does 9500rpmā¦
Thorium x4 right now it is AT version. Getting gear drives and hangers etc for the urethane version from 3Dservicas. Just needed to get motors as well.
190 it isss. Thanks again @professor_shartsis.
This is easy. MR60 are much easier to cable-tie together so they donāt vibrate apart.
Is cold shock a thing for belts? So far Iāve snapped two belts after going from inside to outside and riding not even crazy hardā¦
What am I missing here?
Not unless youāre spraying them with liquid nitrogen. Might just be odd luck. How cold are we talking?
Anyone?
Commonly refered to as dual diagonals. Ollins boards were one of the first to do it and was a popular thing. It doesnāt feel ābadā, definitely feels different, the main reason is not really the feeling but the fact that you have to run motor wires all the way down a board making it not as popular of an option.
No way. Different voltages per cell, different cell count. Donāt even try unless the BMS somehow has a dual mode.
Damn why did that not click!
Thank you @BluPenguin
@Geo_Engineering_FTW here are some good examples
this one is a motor on each truck but you can pop them both on the same truck like shown here which is more practical for the above reasons BluPenguin mentioned
Like -10 ish Cā¦
thanks man, dual diagnonals makes total sense as a name. nice thereās actually a name for it
