Archived: the OG noob question thread! šŸ˜€
Yep I have those on my evolve gt AT hubs they are cheap not super grippy but enough you can still carve. The chinese hubs to go with them are horrid but you dont them. There are a few airless options too but unless you have a lot of issue with punctures I would avoid…
#Aliexpress AU $3.06 13%OFF | 6X2 tube tire for 6*2 inner and outer tyre Electric Scooter Wheel Chair Truck F0 Pneumatic Wheel Trolley Cart Air Wheel Bike
https://a.aliexpress.com/_suw4ge
Yep the ownboards pulleys are a little fatter still with 28mm bearing they fit my evolve trucks.
What bearing size to go with it? Plan is to use them on 8mm axels. Hard to find.
Online I see them labeled as 16100 2RS.
Unfortunately looks like those are 10mm axle and 8mm wide. I’ll find an 8mm ID version.
638RS are 8mm ID, 28mm OD, but 9mm wide. That’s the only size I’m finding in the 8mm and 28mm diameter. I also see them listed as 638zz.
This site looks promising
https://www.hibike.com/enduro-bearings-628-ball-bearing-628-llu-abec-3-max-8x28x8mm-p9e8b271b3b4dd35414e672d3fb15bc9a#var_87920107
Can I pull the hall sensor unit off of my motor?
What’s the cheapest way to protect a deck from riding in rain? I sanded clean a old bamboo deck to 320 grit and hit it with a couple heavy layers of krylon colormaxx paint + primer…is that enough?
I can grab a can of Rust-Oleum crystal clear enamel to put ontop if need be
you may… but only you truly know if you can!
Random question I was asking myself: why would some focboxes have that marker mark on the inductor but others don’t. Or might it be a burn mark?
I’m trying to program my Unity for the first time, but the only way to get it to stay on is when I press and hold the power button. I held it down while connecting to the Ackmaniac ESC Tool and that worked to connect and run FW upload, but it still turns off after I stop holding down the power button. What am I doing wrong?
Uh, weird. unplug the switch from the unity and CAREFULLY short the pin. The switch is a momentary, should disconnect after the press and the unity stays on by itself. The switch might be bad. Or you have the Unity auto shut off set to 1 second or something.
Edit: I take it back, press and hold the switch while you yank the plug off. Safer than shorting the pins. It should theoretically stay on after you yank the plug.
RS I think means ā€œRubber Sealā€ and 2RS means rubber on both sides of the bearing
Z means metal shield
ZZ means metal shield on both sides
Probably just from an internal process at the factory. Maybe one of the workers put that there when they assembled or tested a certain part
Any of them. All that matters is technique. Took me about 10 mins to get good after going thru this. For 2.54PH, I had to use forceps/pliers after the fact to slightly compress the sides for it to fit into housing, but that was because I was using an absolutely trash tool.
Crimping is a beautiful skill for DIYesk8 IMO. I hate wires that don’t have silicone insulation, and I hate splicing small wires in general via soldering.
Here is the good info IIRC
I forget if this one has good info. It might, I advise checking it out.
No one is gonna see this…
But - the trick so soldering male JST PH/ZH/whatever pins - pull the pin out of the housing… Solder to your wire… Push back in slightly, mate to female, then push rest of the way. Holds just fine on its own, but I still recommend a dab of superglue/epoxy on the pin/housing for bullshit proofing in esk8
properly crimped wires are stronger than equivalent soldered connections
and… I saw it… I see your point… but nah… I’m not going to super-glue pins into a JST connector.
fight me
Fuck that, vibrations are killer
You might be right, not debating that.
But for me, I trust nothing more than shit that’s soldered together then acrylic then heatshrink then more acrylic
Had too much shit break in too many different ways to leave ANYTHING up to chance
If my theory is right, you could take a ā€œproperly crimpedā€ connection, and add solder and it’d be even better than just the crimping alone
Crimped is better than solder for larger gauges, using the proper crimper and lugs.
It cold welds the metals. If you’ve never cut into 2AWG or larger wire crimped with quality lugs at 10+tons of pressure under a microscope and seen solid copper, you wouldn’t understand haha. The solder joint would break under vibration before the cold weld.
Each method has its place, and there’s a lot of ignorance surrounding both methods.
Not amazing crimped smaller wires can be better than soldered small wires as well. Many novices will wick waaay too much solder up >22awg leading to a fragile portion of wire.
my experience in decades of off-road racing has shown that a properly crimped connection will survive longer than a similar soldered connection… we’ve only had a very few failures and those were soldered…
my 'lectronics guru says un-necessary, and the heat is your enemy in this scenario… he has even more experience than I…
BTW I’ll get you some pix on the bi-metallic corrosion soon… I found it very interesting…
You don’t need to super glue them. Think about this though. If you solder them in the housing, how do you know you’re not heating it enough to permanently expand the pin hole more than taking it out and pushing it back in? I really think the pull out method is great ( hurr durr sex jokes here ) in a lot of cases.
If you like soldering to 16 1.5mm spaced pins in chintsy ass plastic housing tho… Have your fun :stuck_out_tongue:
Definitely sounds like a high desert thing to do… After the meth of course.
Unless he’s an ā€œesk8 electronics guruā€ then he doesn’t know about the harsh, heavy, and extreme vibrations that esk8 have to endure
This shit is in another league as far as the amount of robustness needed
Vibrations will kill everything and anything in the most unexpected and the most expected ways. They are evil
