Yeah I may be a dumb ass noob but I canāt see feeding the Comm wires and CAN and PPM wires out unless notching the lid. Also I donāt see how I can get the receiver in there. Not much room unless I take it apart than Iām afraid of radio interference.
@Aeromech787
Make sure you plan it out. Example: do all the wires you want to use fit towards that location, does it make it too bulky for the lid to close. Wouldnt want to dremel the lid and find out you have to jbweld it
I would just drill a hole, put wires through it, then seal around the wires with maybe neutral-cure silicone
Seal them while itās open though or youāll never be able to get it open again
Measure twice cut once. Got it.what could go wrongā¦
I was thinking the same but through the heatsink area.
I paid a lot more for my Enertion vesc and those were bad from the manufacturer. These cost less and are much heavier duty.
If it were me, Iād either do what @b264 said and drill, then goop with silicone, or Iād 3d print a new lid with a hole already in it.
Ok so I need to buy some new ESCs.
Looking for 2 singles to probably connect by CANbus and run a dual setup. Want something strong and reliable.
2/Maytech 6.8 superfoc vs 2/Flipsky 6.6 singles
Will use a loop key as anti sparks sound fragile.
@b264 will suggest dual receivers ( which I am considering - but need new remote receivers etc thenā¦hmmā¦)
Advice / recommendations / better options?
I have this ESC. There are two small notches in the small removable lid in which you can run the wires to receiver and sensor.
It is tight doing up the lid but mine still works.
If your budget can accommodate them, Vesc 6 are the current best of class:
Cheers Bill.
Yup, they aināt budget.
Cost is going to be the issue there. They will be about three times the priceā¦
Hey, out of my wallet league as well.
Anyone have any suggestions or methods to prevent the Allen head of motor pulley setting screw from slipping?
Had mine slipped and needed to glue an Allen key into it and sacrifice it
Would there be a way to extend your batteries cycle life by charging to say, 80%? I know most batteries get more life from not charging fully, but would there be a way or a BMS of sorts that does it automatically to extend the life?
There are BMSes that have more or less configuration just like different ESCs, looks like this one comes with software but yah would just have to search specifically for if the BMS has some sort of connectivity where some software can interface with it and that it provides that option (I imagine most that have any software interface would allow you to set max charge voltage since itās probably a pretty common thing to want to set).
List of ones with some sort of connectivity from BesTech here https://www.bestechpower.com/communicationbms/
looks like DieBieBMS also has a QT based UI for configuring that kind of thing.
What kinda antennas do people use on the metr pro? Is the large one needed?
Deciding which to get. (Lmk if you have one too many)
First noob question.
So uhhā¦ what does 10char mean?
Forum restrictions have minimum character length for posts usually complains your post is less than x characters (10 in most cases) so people add 10char to make the message go away for quick responsesā¦ I basically never need thisā¦
