hell yeah
tsg pass helmet matt white for 166€ new
talk me out of it guys, i allready have a regular non-fullface helmet…
aside from keeping my face, will this help with cold weather too ?
@eBoosted makes the sweetest enclosures
https://www.eboardsperu.com/
It’s him and @BigBen these days for sure.
My board tops at 46km/h, so according to this calculator, I’m loosing around 10km/h? Could this be? Where and what can I loose?
your motor pinion is 12t
I think the 90% efficiency is closer to what urethane wheels get I’m not sure what inflated wheels get…
@moon I have both, and 11t is in use.
@AngryTrucker I’m not sure about this, maybe 90 is for hubs, and ~85 for geared motors. I do believe, that the amount of air in the tires makes a difreance, since the tire can change in diameter, but the loss of 10 seems a bit much.
what are you using to record your actual speed?
any gps app.
Hey guys, do you think this sound could be coming from a bad bearing?
I opened the motor up, but don’t see anything suspicious except for a bit of blue loctite that the previous owner must have spilled in lol
I’ts a Maytech 6374. How hard would removing the bearings be / how could I check without removing them to find out which of them is causing the sound, if any? Surely this isn’t safe to ride, right? I don’t want the motor to jam up or anything…
you can NEVER go wrong with a full face. my face thx me in the winter months. fog is the only concern.
@mmaner My title is gone
EDIT : Is back again
I have no idea who would do such a hateful and wounding thing. I bet it was @BillGordon, he’s such a sadist
Poor pupper…
@BillGordon explain yourself!
share the link?
its a regular amazon link and i had 15€ coupon for installing the amazon ios app, thats how i ended with 166€
“Ready to ship in 1 to 2 Months” well…
Hi, I’m probably going to build an electric skateboard for next year. Here are all the parts:
- Deck: Landyachtz-9-two-5
- Remote: Flipsky vx1 or vx2
- Vesc: Flipsky 6.6
- Motor, wheels: TB Direct drive 90- or 75kv + 110mm wheels.
- Battery: TB 12s4p
- Bullet connector 2x
- Sensor wires 2x
Four questions:
How much more powerful is the 75kv direct drive than the 90kv, is there a big difference?
Do I need any other parts for the build?
Should I get the flipsky vx1 or vx2, is the screen worth 50$?
Would it be better if I went for a dual 6374/6380? More powerful? If so should I get the TB 6374 or 6380?
I am comfortable at high speeds on a longboard.
wow ok seems i got lucky then, mine should arrive on the 21st, ordered today
