There isnât anything wrong with discharging through a BMS if you do it correctly. In fact itâs safer in some ways, and more dangerous in other ways.
I personally donât like the idea of the BMS being able to disconnect my brakes because it thinks the battery is already fully charged and doesnât need any more juice.
However there are pros and cons to both ways.
See the thread for that
Those bolts have threadlock. Always heat those bolts up before loosening the bolts especially if you feel its tight. @xsynatic
It happened while screwing it in and it wasnât even fully tight
ow no⌠still not fully tight?
No not really, there is still room.
Can someone post the link for windows FocBox tool? The links from esk8 builders arenât loading for me
I have 2 of these in current builds and never had a serious issue. One did go into protection mode one time but that was my fault and the first one I had saved my house from burning to the ground when I wired up an xt90 backwards like a fool at 1am while 10 beers down.
My evo runs a special order 100 or 120amp version on a 12s4p and never has it cut out from over regen. I would recommend these because I actually have used them and they work.
Mount it to the bracket so you can tug on it. Give you something to hold on to. Should slide off
Those screw arenât supposed to go in until the head hits bottom. Theyâre supposed to go until the end of the screw is pinching the shaft.
You need @taz
Bottom left is b- middle should be p-
That diagram shared up post a bit came directly from bestech when this was discussed in the Deadzone a while back
Still not going then?
yeah Brian had that brilliant idea (not sure why i didnât think of it.)
Yâall know those red waterproof BMSs? I got one and the black side of the case is dented, likely that the circuit is damaged?
Send some pics
What is the default cutoff for the unity out of the box? Cause my cells are at 3.7v each but the unity isnât turning on. My board is wired correctly, I know because itâs charging fine. I replaced the default switch with my own 12v momentary switch, and wired it how the other switch was
@Jacob I didnât know you had Unity. The software I linked wonât work for that, itâs a custom layout and only the enertion software will work.
Anyone have a handy link for the Unity Windows software installer?
