Ya I was looking at getting those a while ago, but I need 8mm shaft.
I assume it’s 10mm for a good reason.
10 > 8
Moving from 8mm to 10mm shaft dia correlates with a direct 67% increase in metric BDE units.
i lucked out i ordered 6 shooters and SR RKPs. lucky for me the shooters can do 10 or 8. I had no clue
That’s more shaft-twisting force than you use on Sean.
Its not that I wouldnt use 10mm. Its that it wont work with what I want to do.
Never said it wasnt.
You just need to find a bigger hole.
I want it for the spiral bevel gears I ordered. It says it only works with 8mm. Maybe when I get it in my hands i can see if the pinion can be bored out.
Did you contact them to ask about line samples/MOQs?
Sometimes these companies have samples left over from other runs, never hurts to ask.
The shaft can always be stepped down.
You’d likely want lower KV as well given the gear ratio of the spiral bevel too, correct?
While ya here Andrew, for all us Europeans, How to you pronounce @SeanHacker name?
‘‘Seen’’ or ‘‘Shaun’’
It’s pronounced: Shitlord.
That’s dickhead to you…
Yep. Just like that one. ![]()
Not your wittiest retort, but we’ll grade overall on a scale.
It was a throwback, a staple in comedy.
Try to keep up old man.
https://forum.esk8.news/t/show-me-your-pets/673/10?u=derelictrobot
Also do me the benefit of ignoring my edit.
As you wish, Shithead.
Bill stop changing your own title and start changing Darens for christ out loud
@Dareno what does sous-vide mean
French for vacuum-sealed food. makes it worse doesn’t it :).
