Can you inspect the jst connector. look at the wires going inside it and see if anything is loose, maybe a wire got pulled slightly.
I even resoldered all connectors to be 100% sure.
I really dont get it, you guys are my last hope
We are just Morty’s*
Im even thinking of taking the motor apart, but i really dont want to if i dont have to.
Btw updated vesc tool to latest version aswell, and was actin weird a bit yesterday.
I have had motors detect better in Ack than official Tool, and vice versa.
Did you swap motors and see if the problem follows the motor or ESC?
Just ran motor kv calculations 29540 ERPM / (36.4V * 7 pole pairs) = 119kv…but the motor is supposed to be 140kv, is that okay and did I get a free +18% torque?
It’s rather like a PA.
What happens when you hand-test the motors while not connected to any ESC?
I recently had a motor that consistently fails step 6 and which was smoking ESCs, but otherwise appeared normal.
Do it without wheels for a truer calculation.
How much should it go up if I do? I takes about 10 minutes to get the wheels on or off so I’d rather not
Thanks. i knew it wasn’t an XH or PH so i have been trying to google for the last 30 min ![]()
Danke!
Is that what you meant @mmaner
I don’t know, depends on the battery, wheels, gearing, etc.
Yes, if I’m understanding and the issue happens on multiple motors and a single ESC, then logically the ESC is the issue.
I did your whole test method and nothing out of the ordinary.
And @mmaner it follows the motors.
Motor 1 on esc 1 = perfect
Motor 2 on esc 2 = problem
Motor 1 on esc 2 = perfect
Motor 2 on esc 1= problem
Tried with and without sensor, also did all manual checks.
On FOC the motor spins but on BLDC nothing happens.
When doing the setup for BLDC the motor spins up.
After setup = no reaction
I did the whole same procedure on the other motor and no issues.
Ok, the the motor is the issue. Have you disassemble it? It could be a filled bearing offering too much resistance, a displaced or broken magnet, a partially disconnected phase wire, etc.
Conclusion?
Faulty motor
Try manually entering the detection results from motor 1 and driving motor 2 with those values. Assuming both motors are the same make and model and Kv
