those were popular few years ago, they look like they are 0Ā° same as MTB.
any more suggestions on how i could fix this ?
should i try making an āadapterā out of epoxy that rests inside the clamp ? im really looking for a non permanent solution
Iād suggest using some shim stock - very thin sheetmetal used in machine shops and the like. Itās available in a lot if different thicknesses from <0.001" all the way up to regular sheetmetal thickness, and available in lots of different materials too - steel, stainless, brass, etc. Itās available from McMaster, Amazon, and a lot of other places.
Basically get some shim stock and use it to fill up the gaps between the clamp and the truck.
To answer your earlier question directly, it is possible to just space things farther apart, but IMO itās better if at all possible to keep things as close together as possible to avoid excessive bending forces - I actually broke a motor shaft clean off by having my belt too tight.
Youāll need bearing adapters that sits inside the superstar rim and takes 608 bearings. These are boardbumpers and Trampas offerings:
thanks for those suggestions guys, combined this could become a really cheap and easy fix if i can pull it off!
Straight forward question. Will two 6384 motors fit on Torque V5 motormount with 218mm trucks? (inward mount)
Thanks
Iām pretty sure no, 6380 would be the biggest you can fit.
Does anyone have a picture of hummie deck next to prototypo? To compare the stanceā¦
looks like 5 pin JST XH or JST PH
i have a funny newb questionā¦
why is there no dual remote /slidepuck solution that allow control in the opposite hand while one slidepuck is on the ground ?
in my puny mind this sounds like a lot of fun
Weird things happening.
Yesterday setting up my board = no problem
Today 1 of the motors does not want to run in BLDC mode.
When switching it to FOC the motor spins.
Motors: Flipsky 6374 3250W
Anyone?
Did you rerun motor calibration?
yes I did, the other motor does just fine.
swap the left motor phase wires with the controlers right phase wires and same with the other motor and tell me the result
To be clear, BLDC sensored or unsensored?
All done, its not the fsesc.
Still doesnt work when connected to the second esc.
Btw: second item from Flipsky that gives me troubleā¦
Sensored
Can you pull them and try again?
Also done, same result.
And no touching or exposed connector on phase wires?
