I’ve been thinking about deck building. When making the press mould, do the top and bottom halves lineup perfectly with nothing between them or would I have to take into consideration the thickness of the deck and cut the mould with that in mind?
@Sn4Pz Why not get the Sanyo NCR20700B 4250mAh - 15A instead of the Samsung INR21700-50E 5000mAh - 10A ?
slightly less mAh but more A and cheaper?
Do you know if these cells are any good?
Vapcell INR21700 4500mAh - 20A
I could make an offhand comment about how the Samsung 50e probably has less sag while running at 10 or even 12a, which is totally possible. Buuuut I’ll do some research and come back in like 10 minutes
Thanks Caden! i would do the research but i don’t treally know what to look for in batteries
This is for lights and powering things alike, not for the eskate itself
At 10a for both batteries:
The Samsung 50e sags to about 3.9v and gets about 4430mah of usable juice
The Sanyo sags to about 3.85 and gets almost 3825mah of usable energy (Please come in and tell me if im explaining this wrong )
For what its worth the Samsung cell also stays cooler, but only by a few degrees, ±5 or so.
That Vapcell is essentially the Sanyo cell, it sags to 3.85v under 10a, and has about 4250mah of usable power
I got these graphs off a member of the vape community named Mooch, he tests alot of cells and tells you what he thinks of them. Pretty useful resource for Esk8.
(Yes its a keeppower, its basically your sanyo cell, there weren’t any tests directly under its name though.)
(These Eizfan purple Blacks are samsung 50es, just look at the graph )
I don’t have a printer myself actually… I’ve located some people in my city who can print for me with polycarbonate. Thx for the info
Quick question about voltages, specifically 12s vs 8s. Does a higher voltage only increase top speed, or does it also affect torque? I feel like going 12s should allow the motors to run cooler because you are drawing fewer amps, is this right? Basically, on the exact same setup, except going 12s instead of 8s, will I lose acceleration and torque?
@Jbev 12s vs 8s doesn’t affect the torque, only the top speed. the motor current limit affects the torque.
8s will accelerate just as fast as 12s with the same motor current limit (to a lower top speed).
12s will draw less battery current to supply the same motor current, and give the same torque and motor heating as 8s assuming the same motor current limit is used.
guys i have a quick question…
with my e-caliber trucks and mounts, since the hangars are becoming thinner towards the end, its hard to align the clamps further out,
so how bad is it if i mount them a bit more towards the center and move the motor pulley out like 3 millimeters to accomodate for this ?
will this put a lot more stress on the motor axle ?
this seems to be the only solution the align all this somewhat straight
@Jbev I should add that if your battery current limit is less than your motor current limit, then at the upper end of your speed range, your power will be limited by the battery current limit, not the motor current limit.
in this scenario, if you use the same battery current limit with 12s vs 8s, and the battery current limit is significantly lower than the motor current limit, then at the upper end of your speed range, since the same battery current limit equates to less watts with 8s, then the same battery current limit will result in less motor current in the 8s system at higher speeds, and that lower motor current will result in less torque and less acceleration.
only at the lower speeds, the controller is able to simply draw more battery current from the 8s system than the 12s system, to supply the same motor current, torque, acceleration and motor heating, while also staying under the battery limit setting.
this scenario of lower torque with 8s at the higher speeds will only will happen if your battery current setting is less than the motor current limit setting.
if the battery current limit is the same as the motor current limit, then the torque and acceleration will be the same with 8s and 12s, but the top speed with 8s will be lower.
close to your top speed with either system, assuming proper gearing, the motor current isn’t limited by the motor current limit setting or the battery current limit setting, but rather by the back emf voltage produced by the interaction of the spinning magnets in the motor with the stationary winding coils. this back emf voltage, which directly opposes the battery voltage, is of equal magnitude and value to the battery voltage at no load speed, and it prevents significant motor or battery current from being utilized which effectively prevents further acceleration.
How do I wire a 3 prong switch with Bestech BMS 2 white wires? From what I gather online the brass colored prong is negative, the middle one is positive, but what do I do with the 2 white wires? Connect to the third prong?
Any help mucho appreciated.
What material can I put on the sticky side of longboard griptape so I can easily remove and reapply the grip tape?
Ill just get new grip if it’s not worth the trouble lol
@Jbev taking things a step further:
bemf_voltage = motor_rpm / motor_kv
pwm_effective_voltage = duty_cycle_%_bldc * battery_voltage
winding_resistance_ohms = (foc_resistance_detection_one_phase_milliohms / 1000) * 2
motor_current = (pwm_effective_voltage - bemf_voltage) / winding_resistance_ohms
torque_newton_meters_per_motor_amp_KT = 60 / (2 * pi * motor_kv)
motor_torque_newton_meters = torque_newton_meters_per_motor_amp_KT * motor_current
battery_current = (pwm_effective_voltage * motor_current) / battery_voltage
The Caliber E trucks are a PITA for this very reason. What you’ve said will work, but it’s not ideal and puts more stress on the motor bearings causing faster wear and very slightly lower range.
A better solution I’ve found is to get the clamp in the correct spot – even if you have to put a tiny shim under them – and then once you are sure they are in the correct place, JB Weld them onto the truck hanger and don’t ride on it for 3 or 4 days. They won’t budge. They will also be permanent, never separating from the hanger again.
Do you have BMS photos?
A switch simply connects or disconnects the three prong ones are usually going to be one that supports being “on” in different toggle positions depending on which pins you connect (normally open or normally closed). Easiest way to see what’s going on is use a multimeter in continuity mode to test which pins are connected to each other when the switch is toggled one way or another. Typically there is one common pin and one pin connected when the switch is in off mode and the other connected when the switch is toggled the other way, one pair of the pins will never connect the third one is the common.
Edit only other reason I could see more than two wires going to a switch is for an LED but in general two pins is regular switch only turns on when in on position three pin it can be connected or disconnected when in “on” position (can be connected when in off position as well depending on which pins you hook up, should be no danger in just trying too though switch is same as just hooking those two wires together).
So how do you get the motors off if you can’t move the mounts off the hanger on a dual setup?
That’s a good question. I use single setups a lot of the time. I guess you would saw the mount plate with a hacksaw.
I think a good solution would be JB welding one mount down and then using some kind of cross bars to hold the other one true with the help of the one that is JB welded in place.
I mean, why not?
‘‘Michel, where did those 40$ go that were in my wallet?’’
‘‘Oh, sorry honey! just had to get a new motor mount…’’
