Yes that’s right.
oh ok my bad lol, so i was putting in a randal baseplate. I just got off the phone amazing lady! So the Randles internal hole is same as TB218’s but the outer wall is thicker.
So i need to order randal pivot cups DOH!
Speaking of that are you guys running Magnums front and back for bushings? Im 225lbs
Do people prefer red, blue, yellow?
- Red
- Blue
- Yellow
0 voters
Yes it very much matters. You also need a fuse in that connection
oohh can you tell me more about that?? how do I do that/what is the purpose & what happens if I don’t use a fuse?
Yes it does
Put one of these on the negative wire
https://www.mouser.com/ProductDetail/576-099707.5WXN
So the charge port jack negative goes to the fuse, then the black JST wire goes to the other side of the fuse
The fuse’s job is to destroy itself if there is a problem – before your battery or anything else destroy themselves
There’s your problem.
JK
Hey, I started on an Evolve and until it broke recently, still took it out occasionally. If I did it all over I’d start with Metroboard then do DIY while riding that
Does anyone know where to get 80mm motor mounts?
@PixelatedPolyeurthan
If you go hydro dip, wear gloves. It took me 20 minutes with mechanics soap to wash it off
How are you going to get it off your ring? You better let a jeweler do that
I know right…
Sure. but i paid my evolve for 1200 euros and it was quasi new so that is how it got me into diy so i am happy to that i bought it. But very pissed off that i am spending hours to try and fix it.
That may have been the best tip i have ever heard.
You want a fuse rated a little higher than the current output of your charger, and a higher voltage than the battery at full charge - if you have a 4A charger, 5-6A fuse. 10A charger, 12-15A fuse, etc.
The one Brian posted is perfect.
If you don’t have a fuse, then if you or someone/something else causes a short between the pin and ring of the charge socket on your board, the full battery current will flow through that short, causing smoke, fire, sparks and mayhem.
With a fuse, there will be a little spark, maybe a small pop and your charger won’t charge the board until you replace the blown fuse. No drama, no fire.
Use a fuse.
This exact thing has saved my boards before. You can even ride the board one more time before you fix it
Guys my loopkey is making small ora ge sparks when inserted since the last two days. Any ideas why this happened? XT90S Loopkey sparking when inserted
