What are some great trucks too use with evolve hubs? (will be using 8” mbs wheels) I’m thinking of doing a deck swap on my commuter board & use the MBS trucks on a future mountain board build.
Sir I would love to have a couple beers with you
Those would be nice. Was thinking more like caliber style since I have mounts for those. Are the e-caliber roomy enough for the evolve hubs too fit with there pulleys? I also hear evolve tricks are not good for speed
I just sold mine but i can give you rough dimesions.
4cm x 8.5cm (maybe 9cm)
why only unsensored? can it not work sensored?
I only like DKP on the front. Not a fan of DKP on the rear trucks. So I guess I’m halfway between you and @Psychotiller LoLz
Because they have 3 conductors instead of 9 conductors (3 large, 6 small)
You can still use them with a separate sensor cable
char
Thanks a lot
Evolve also has a newer and an older BMS version. I don’t know if they are different sizes.
Yes carbon gt
If you use unsensored motors then you have to make sure you have your wires in the correct order first before soldering on a 3 pin connector because you can not change the rotation in the software. Unless theres a sneaky Brian method? Is there Brian? Is there?
You can change rotation direction in the newest Vesc Tool, but better to do it right in the wiring.
With unsensored motors? Don’t think you can. Unless they changed things without consulting me again. Bastards
with the unity you can just swap the the direction of a motor with a push of a button on the app without sensors.
A great april fool prank if you ask me
I have never been able to change the true false aspect of motor rotation on my set ups. BLDC and unsensored. I am and will admit to being one stubborn son of a bitch that will not change his ways.
How I roll.
I run uncensored everything. You can swap it, but it’s a sloppy practice.
You’re starting to worry me.
FOC?
Don’t worry. I often stop by Singapore on my way to Sydney. April is a long way away anyway.
On a serious note though, am i?
