Riddle me this:
Based on Samsung INR18650-30Q spec sheet
Standard charge CCCV, 1.50A, 4.20 ± 0.05 V, 150mA cut-off
Rated charge CCCV, 4A, 4.20 ± 0.05 V, 100mA cut-off
1C charge rate based on 3000mAh = 3A
So it looks like I could safely charge a 1P pack at 3A, a 2P at 6A etc⊠5P at 15A at 1C charge rate
(based on my experience with parallel charging lipo packs)
I, however, see most charge with simple laptop bricks at 2~4A, could I throw a 9A charge current at a 3P pack, or is there something about LiOn batteries, or BMS architecture that precludes this?
that just made it worse ![]()
I need a pic. assuming you are using speed rings on both sides of the wheel, a spacer in the middle between the bearings and the nut is tightened down I just donât see any way the bearings could be loose. Maybe Im just missing something.
So the thing is that I have 2 bearing before the wheel that I am using as spacers (is that ok)
Then there is a speed ring
Then there isnât the bearing
Then the bolt
@mmaner do you understand now
Just cause some people are actually useful and now what there doing
If you think your so clever then you tell me what the problem is
Also is there any disadvantage of putting loctite on the wheel
Yeah iâll stop, but once you put the bolt on the axle how does is just dissapear?
Honestly, not really. It should be fine using bearings as spacers, you could just use the inner race of the bearing, but whatever, no big. I donât understand whats coming off? The bearings in the wheel are coming out of the bearing seat? There has to be something pushing against the bearing to hold it in place, but I canât see whats missing form the pics.
i know that the bearing seat is very loose
Maybe the sound problem is from a different thing
I will upload a video of the sound as soon as I can
I there any disadvantage of using loctite though other then that it is hard to remove
If the bearing seat is loose you may want to use loctite. I had a set of abec 97mm flywheels that got that way after awhile. I just replaced them, but whatever keeps the bearings in place. The problem with the bearing seat allowing the bearings to move out of position is that it will brake the bearings fast, lock you up fast.
K I will try using loctit then see how it goes
This.
I ended up having to make my own enclosure to fit all the crap I wanted anyway. And I didnât start any assembly before that was finished ![]()
The 30q cell can be charge at a max of 4amps. So a 5p pack can charge at 20amps not 30. Doing so would reduce the life of the battery if you charge it with that many amps all the time.
Yeah⊠I modified my post above, math is hard!
Iâm still really confused. What do you base your information from? Science or anecdotal references?
On the 30q spec sheet all of their tests were performed at 4A
They list 2 differing charge rates, 0.5C = 1.5A standard, and rapid charge rate at 4A That is for 1 cell, if you have 5P why couldnât you multiply your respective batteries parallel groups by the amps chosen?
1.5A x 5P = 7.5A conservatively
Admittedly Iâm coming at this from quads, and LiPos where the chemistry is different and we use parallel chargers and not BMS, but Iâm struggling to find out why this isnât appropriate, or why It wonât work.
Ya you do multiple your charge amps Ă p groups. So a max charge rate for a 30q 5p set up would be 4a x 5p= 20amps.
Yes I am familiar, thanks, Iâve quoted the same!
Can anyone tell me what the function of c43 is on a vesc / focbox? Pic attached.
I traded my unity for two Focboxes, yet one is missing said c43⊠PieceâŠthing.
Upon a better look, it looks like this was water damaged at some point. Should I try and conduct another swap? Another normal focbox for this one?
