Let me see what i can find. Phone is at 2% lol
ahh just sandwich with foam i see ok!
When your molding that enclosure to the deck with a heat gun.
You can put something a few millimeters thick and solid between the deck and the enclosure to make a very slight indentation in the enclosure if you’re worried about pinching the wires too hard.
But if i remember right you’re using 3/4 gasket to add a bit of height to your enclosure so you really should be good.
beautiful, thank you @b264
Those are Riptide tunnel risers, one of them I sawed with a hacksaw blade.
those are badass
Hey guys I’m just wondering about my focbox settings and it’s regenerative braking. I know that to brake the motor it puts out some voltage and charges the battery but what happens if the battery is fully charged? Do I have to put a brake resistor on it?
If you’re using your BMS discharge then it will CAN cut off your brakes
(some models of BMS) but if you are bypassing the BMS then it will just very slightly overcharge the battery.
@xatonic I started a thread for this specific topic
Are the king pin 3/8" nuts 16 or 24 TPI?
If anyone finds a link for those
, please share
I’m not joking. I already put it in Amazon but I’m not the best when it comes to FUB stuff.
Does anyone have links (preferably eBay Aus) for epoxy I can use to strengthen my deck as well as go glass frit eventually
Hi, I need to reinstal the entire electronics of my commuter board to a dremeled Haya.
This involve disconnecting my HCX-D596 80A (charge & discharge) from my 10s5p battery, rearrange the P group in a new geometry, then reconnect the BMS to the battery.
I’d like you guys to check the BMS disconnecting order reported below in order for me to avoid unwanted magic smoke:
- Disconnect balance wires from BMS
- Disconnect BMS B- from battery -
- Disconnect BMS P- (power negative) from load -
- Disconnect BMS C- (Charge negative) from charger -
In order to reconnect the BMS to the battery on the Haya deck:
- Connect battery + to Vesc + , loop to charger +
- Connect BMS C- to charger -
- Connect BMS P- to load -
- Connect BMS B- to battery -
- Connect balance wires
is it ok?
Thanks for your help
Disconnect from BMS should be…
0) unplug from charger and pull loop key / switches to off
- load -
- balance
- battery -
- charge -
- all + in any order
Reconnect should be the reverse
I think @Sender or @yelnats8j might
Every epoxy will strengthen your deck. eBay got lots of cheap offers.
Try out-Go
Epoxy itself doesn’t add much strength on its own - it’s usually used as a binder for some high-tensile fiber, such as carbon, glass or aramid. Any general purpose epoxy will work okay for that as long as it’s thin enough to wet out properly.
