I want to know why they cost so much for 4 tires. I can buy 8 clever tires for the same price.
I wondered the same but in their defense…the evolve tires last the longest.
Brah that’s just ridiculous though lol. I know a lot of people who have put shit tons of miles on the clever tires np.
I have a set on my DIY…waiting on battery. Maybe I’ll have a new favorite…Yeah I can get a 6x2 with tube for 10 bucks usd
Yeah, so you see how that is insane right? Idk wtf Evolve is smoking to get prices like that.
They smoking the good stuff😁…I should be asking if the 6x2 will fit evolve hubs…they should the 6 inch evolve will fit
I plan to use the haggy tires until they pop and replace them with the clever 6x2’s. I will say those evolve tires do look nifty but not worth that price at all.
“as far as I can see” won’t cut it. A fraction of a degree is all it takes to throw off belt tracking. You either need to check with a machinist’s square, or just tweak/shim things until everything lines up perfectly.
@Myke That’s on wet surfaces. On dry surfaces they have more grip.
That’s fine I don’t plan to ride when its wet so I will be getting a set soon enough.
Yup, good clarification.
Maybe the battery gauge is set to 6S instead of 10S?
I actually ran into a certain Jason on a group ride and asked him about it and that’s what he suggested as well. When I open it up to put a Metr in there I will investigate further. Cheers
@xsynatic make sure each mount sit the same far away from the outer corner of your hanger.
i would say if you move both mounts 1-1.5mm to the left they have both the same distance.
if you have motor mounts with a press fit clam, than just ignor this…
I use the Motor Mounts from IDEA
I use the matrix 2 trucks. On the truck itself is a screw on each side which holds the axle in place. The Motor mount is perfectly aligned with that screw on both sides.
here you go. the trucks are totally not equal in any means.
the production tolerance is probably the reason for your problem.
might be one shaft is a bit longer or the brake mount hole is not in the right place etc.
If the teeth are 5mm apart (center-to-center) it’s probably useful paired with 97mm ABEC11 china clones.
If the teeth are 3mm apart (center-to-center), immediately dispose of that trash after taking the bearings out.
Looks like a 40T 5m pulley, you can repurpose it for some ABEC wheels
