nah, the output itself is 40.6v
Start shopping for a new charger.
Hi,
Iâm finally finishing my build, but by clearance from the ground to my DD motors is too small with about one centimeter (see below). The current wheels are some ABEC 97mmâs. Iâd like to go bigger to increase the clearance. I think I need at least 110mm to make it sufficient. I was thinking about the foamies or the Rough Stuff or maybe the ABEC11 107mm (which is a bit on the edge). What do you guys think? Maybe something else?
@Mikenopolis you are being summoned on the dark side (builders if that was too subtle)
Thanks. No idea about M1âs esc and receiver
Having a bit of trouble with the Hoyt remote. I have it setup with almost all my boards now for the convenience of a single remote.
I was trying to switch out my 4wd today and Iâm having strange issues. The original remote was a nano and I just used 4way split ppm and everything worked great.
Today I tried to canbus the two neighbor focboxs in each side and do one split ppm to the remote. Itâs acting all kinds of crazy in setup. I can get the wheel setting applied and detected. Then Iâll set the pulsewidth values as normal and hit write config. Then if I try to push throttle the motor that was set up wonât move. The pulsewidth display shows it gontonthe maximum value, but it stays out at 50%. In addition another wheel that was just one the split ppm line would work until I updated the pulsewidth settings and now it does the same thing.
In other words throttling shows the increased pulsewidth but stays at 50% on the display and wonât move motors.
Havenât havens any issues with setting up the Hoyt on unities
Check your trims? Perhaps youâre not on the highest mode?
If you donât ride in rain too often then the TB110 are the wheel youâre looking for.
I donât know shit about the trim feature but I tried it both ways up/down and it didnât help.
Before I changed my app settings in each of the 4 focboxes and had just done a normal motors plugged in through a 4-way ppm split to the nano, noncan bus. The strange thing is, first thing I didnât was just switch the receiver and a few wheels worked without even changing vesc settings.
Changed the first focbox in line as a normal direct to receiver (others were still on the splitnbutnhad and settings) it seemed to be working up until I hit wrote pulsewidth values. Then when I would re-enable the motors to spin and test the remote, the focbox I just set up but wonât spin wheels. When I full throttle the display of pulsewidth percent shoes it rise to the highest value I allowed, but the %bar stays at 50% and the wheels donât move. Iâve tried avoiding split ppm and different setups with the same result. I know the recover adapters on the foc box work, because other Meuse the display wouldnât show the pulsewidth travel to the high value unrer the display pulsewidth spot. So itâs getting signal, itâs jut no longer wanting to work or sees the max and min pulsewidth stuck at 50% somehow.
Btw when I would test a wheel like this out of the other 3, if a other foc box that I had yet to have altered settings from, and the remote was plugged into the ppm line, the motor would work. Under up with any new setting. As soon as Iâd update the setting for what I need, it goes back to the same issue.
Maybe an Enertion questions @carlcollins066
@Resonant Have you tried letting your BMS do itâs job and balance? Just leave it plugged in for a few hours and see if things are getting any closer.
Or you can apply a load manually to that cell group.
@xsynatic 40.6 is not going to hurt anything, youâll just lose a few % of energy due to the lower voltage. I actually like to set my chargers a little below 4.2v/cell for longevity reasons - the cells last longer if you donât go to 100% all the time. If itâs not adjustable then youâll have to get a different charger, but Iâd just roll with it unless you canât stand only reaching ~95% SOC.
Damn man how are you alive at that weight? Are you really really short? Lol
Edit: I saw my answer to this a few posts later.
Are the Tb110 bad in the rain or something? Iâm looking at getting a pair soon.
Well, the TBâs have a kegel core, which I donât have. Iâd really prefer something with a ABEC core
So bad in the rain lol
TB 110 is the way to go. Work awesome with my DDs.
Why does one of my motor pulleys have to Stick a good bit further out to align the belt in the middle compared to the other side which almost touches the Motor mount. Mounts,Motors, pulleys, belts are all the same.
They have maybe 5-10% less grip than ABEC 107s on wet and slick surfaces, but recover nicely.
Maybe a tiny bend in the motor plate? I have one that aligns a tiny bit off just to keep the belt centered perfectly. Only bothers my OCD, not my ride.
So far everything is straight as far as i can see. It doesnât affect my ride but like you my ocd kicks ins because there has to be a reason for it.
As for the Belt whine i posted some time ago, i swapped a belt where it came from and rode for 200m without sound, after that it came back. ÂŻ\(ă)/ÂŻ Bothers the f out of me.
anybody know if the 6 inch evolve tires will fit the six shooters
