Youâre using the old version of the Flipsky 4.2 Plus based on the pic you shared, the 3 PPM cable plugs into the VX1 receiver board and the extra blue single cable got to the positive lead of the VESC for the battery LED reading on your remote.
Without that your remote wonât show the boardâs battery level
Pretty sure I have the newest one. That picture is just from the website documenting the connections. There is a extra white wire for me, not blue, which is the one Iâm going to connect to the positive VESC lead.
Edit: Iâm dumb. I found the extra blue wire in the box. I think I understand now: blue wire only needs to be used when using the 3-wire cable, but if Iâm using the 5-wire cable, then I can just plug it in and the white wire will go to the positive lead.
If youâre using the latest one from them, the VESC actually have a port to plug in the whole receiver without using the extra wire for battery level and the 3 wire ppm cable
The one in the red box just plug the whole receiver in
If your VESC doesnât look like the one in the pic then you have the old one
I think this VESC has an issue where it cuts off if you set the motor current too high >30A
The mod on this was to change the capacitors or something to make it runs better on higher amps but that isnât something that is easily done for noobs like me
I used this VESC previously for a bit and used a AS loop key with it too, ran on motor current 30A/-30A with no issues
You can replace them if you want, if it is like the horrible stiff stuff that comes with hobbyking sk3âs I would probably replace it simply because they are so short and stiff. Surely the flexing would eventually break them
I donât think it is too horribly difficult to replace them and there are probably tutorials out there. All my motors are 12 awg silicon wire but that is just because I received them like that
