I’ve learned that the matrix Profile is so big, that the profile can be off. My mounts don’t perfectly seal the hanger, but the clamps are 13mm thick so it literally does not matter.
sealing the hanger requires tricky machining for a 1 piece mount/clamp too
Love the feedback. Thanks man!
ATS.12 trucks (white) have only ever had 12mm axles.
Normal ATS trucks (aluminum colored like the ones sold on Atom 95X mountainboard) have 9.5mm axles. If you think you got sent the wrong part message me and we’ll sort it out.
I have some of the 9.5 and they bent pretty quick. Do not suggest
Hi @MBS, do you think it will be possible for you to kindly share also the baseplate files for the matrix II ?
@Esk8_ru you might find this helpful as well. At the top
https://forum.esk8.news/uploads/short-url/enPtwSXD9XGinqHJlxYFdIDPYFU.STEP
This would be awesome! I tried my best to model it here. It printed and fit my hangers.
I wasn’t aware that you did the modeling ! first of all - thanks !
I tried to create a riser, after printing it, I’ve realized it doesn’t perfectly aligned with the matrix II baseplate. It does however perfectly fits the holes, but the outline is a little bit different. Thus, if you put the original pad with my printed riser, they will not perfectly match.
TRUCK - MATRIX II - TOP TRUCK - ALUM - ASSEM.STEP (1010.1 KB)
Is this what you’re looking for?
Okay, now where’s the ones for Matrix lll ?
