I’d like to fit some 110mm thane wheels to my Trampa mini infinity trucks . Something like the torque board wheels . Anyone know if this is possible and can be done without modifying the hanger . Failing that I’d consider 97mm wheels
Cheers in advance
Should be some info out there somewhere about what bearings you need.
You would need to use bolt on pulley but they ight w/ kegel, unless you could get a funny bearing to put in a push fit pulley.
I’m not 100% sure the pulleys will line up or if you have some adjustment on the truck mounts or whatev.
Also depends on your hanger position, I have 100mm with the “short” position plus an angled riser and just avoid wheel bite by 3mm. Using bolt on abecs btw, but yes those bearings will be pain to use in most (if not all) push fit pulleys.
We’ve seen truck failure before with this setup but can’t remeber if it was Trampa or MBS.
There was an old thread on .builders
Just FYI
Was it Ernesto when he was using the 100mm mbs wheels trampa trucks where cracking…
Yeah it was knobby 100mm MBS on Trampa ATB trucks, the problem is stress vibrations and on these channel trucks there is no bushing between the baseplate and the hanger.
If you talking about 110, especially 74A and you’re not heavy and you don’t do the kerb thing YMMV
Edit: the MBs 100mm all-terrain urathane wheel
Mmmm ?
Jump off sidewalks and act like a blaggard at every road deformity
so i have a small spacer between the back wheel and the truck, and i had to file half a mm from the angle of the square section of the truck so my 40t can turn freely
hmmm i’ll keep that in minde,
i didn’t think a bigger wheel would give more vibration, actually i thought it was the opposite
The baseplate and hanger on a channel truck are bolted together directly via the kingpin, unlike a skate truck which has those parts separated by a bushing.
We’ve seen the failures, but yeah you would have to be using bumpy wheels, fat and a maniac or a variation of that.
Pneumatic tires provide a good cushion which make up for that lack of bushing, they are of course designed with air tyres in mind unlike skate trucks
You are correct, bigger thane is better, those are the right thane wheels to go with…nice build storylines!
yeah makes sens i’ll keep an eye on them
trampa sells the carver with 90 thanes though so i hope i’ll be fine with the 110
There’s only been a couple of cases and they were more exceptional due to contributing factors
Hi so what parts did you use to get the wheels to fit ,did you have to file the trucks for pulley clearance?
Is this referring to the pic of the Trampa board with the torque wheels fitted shown above,basically what I wanted to do in my post ?
Hi ,what pulleys did you use ,and bearings and where did you get them ? Also did you need to file the hanger for clearance (sometime I’m not really keen on )
Cheers Ja
exactly
