Need to add like 3 inches of rise on my deck so the bottom has decent room.
Its one of those lowrider decks with trucks boot area being higher then rest of deck.
Have an 1.5 inch (riser pads plus 2 shock pads) but thought about making one big piece out of wood to see how it goes.
Would sandwich wood in between shock pads to act as gaskets.
I figure the wood would settle and get squished if you want, with the occasional bolt tightening i think it could work. (Until i hit a crack in the road and wood cracks)
I could also customize the wood piece.
Any thoughts? Has anyone ever tried? (I figure back in the days that would’ve been the go-to way to do it)
Hmm that could work well. It probably would work best if it was a solid hardwood or something along those lines. When plywood cracks on the ends it usually ends up splintering more, probably wouldn’t have that effect with hardwood.
Source: The back and front of one of my old boards is basically gone and splintering, tightening the screws just digs into the cracked bits even more
The only thing you need to know is to add a solid half inch around your holes so its not too weak. Also, make sure it is a hard wood. If you can gouge it with your fingernail its not going to work very well
Edit: add a bit of epoxy or spray laquer for wet conditions.
