I’ve tried everything. Punching it. Swearing at it. Promising to take it out for ice cream. Even holding it over an alligator infested swamp yelling “ POP QUIZ FOC BOX, YER BEING DANGLED OVER HUNGRY ALLIGATORS GOING 55MPH ! “ and then giving the ultimatum live or die? Followed by squeezing the nose and saying “ HONK”.
Still nothing.
I’ve gone through set up using the vesc tool on windows and everything checks out Aces but after disconnecting, spending 45 min of preparation listening to Survivors “Eye of the Tiger” on repeat and going step by step through the Hanson Brothers ritual of putting on the foils. Then finally entering the Thunderdome for some rubber vs asphalt hand to hand combat the only action I get is hand to gland combat.
Has anybody figured out what style of Kung Fu will turn a large expensive paper weight into a Bitch’n shred sled that’ll finally get girls to notice me,like me and let me touch their boobies?
I’m just home on my Unity + VX2 Pro board so it does work but you’re correct that it’s a pain in the ass. The easiest troubleshooting step I remember is in the VX2 settings, alternate between focbox and FSESC mode. If that works you’re golden, though it might not give you speed on the VX2 now?
Failing that, do you definitely have UART enabled? You don’t need to do PPM calibration or anything, and it may interfere.
Finally, are you on Focbox firmware (23.xx) or VESC firmware? I’m on Focbox fwiw
Yes, plug in bluetooth 2.4Ghz receiver provided w/ vx2 into unity. Run VESCtool using UART mode (skip remote setup in VESCtool). Pair remote via remote on screen settings
No issue with Unity and VX2 here. Make sure you change it to FSESC if you are using VESC software. Change the input setting to UART and good to go. And double check the wiring order.
Had to borrow my bud’s PC because I’ve got a Mac but I think the firmware was 5.2
Not sure though. Looks like I’m gonna need to borrow it again and try some different approaches.
Thanks
