Aluminium board and carbonfibre enclosure
Damn they look awesome! I had to shim my wheels about 2mm on the rear to be able to fit the wheels without them hitting the screws of the gearbox so yes they are offset but not by much :slight_smile:
ok, what im gonna do then is make them a bit wider inside than the wheel is and just put a lil bit of guesswork on how deep one part is, unless you can give me a rough measurement :stuck_out_tongue:
Nearly done i guess, but i dont wanna waste your precious filament
Fender 1 120 mm foamies.SLDPRT (328.8 KB) Fender 2 120 mm foamies.SLDPRT (439.3 KB)
Here are the two front fenders, they should fit according to my ofcourse, cough, very accurate skills.
this is a picture of them on a normal caliber truck
can upload stl. files too if you want, but you can see now how i made it and copy me :slight_smile:
will probably also strenghten the inner part a bit tomorrow
Owww fudge, i also forgot u have the extended axles with those torqueboards trucks. Will also take a look at that tomorrow.
That mounting solution looks awesome,great thinking :). I will test-print them later tonight
beautiful :ok_hand:
here are the new versions, they are stronger in the center and go over the truck farther so you can use some spacers in between for the torqueboard trucks.
Fender 1 120 mm foamies.SLDPRT (327.2 KB) Fender 2 120 mm foamies.SLDPRT (439.2 KB)
i recommend putting some rings between the truck and the fender, then the wheel against that.
also these files are mirrors of eachother, so if you open both you can adjust one and the other will mirror this.
Dude you just knocked it out of the park! Imma print these asap! They are going to look awesome :slight_smile:
because i dont know the exact sizes, you might want to dremel some of the edges off if it doesnt fit the hanger
No problem,will do if needed :slight_smile:
Dud that’s awesome! I mean helping a brother out an all. @wasp awesome board.
Hey, did you print the fenders and did they fit the wheels/trucks? I hope so bc otherwise i would have wasted your material. And if they dont fit can you show me so i can fix rhe issues?
Hey! I havent printed them just yet,im waiting to get home some tpu filament :slight_smile:
Oooh well if you can open it with solidworks and add your measurements of the truck to the hole you are safe for sure :smiley:
I will do that :). I still have my solidworks liscense left from school luckily
