Couldn’t agree more. I wish one of these ali tire makers would color them! No one mention the fake trampas
I’ve got about 100 miles on these tires on a variety of trails- asphalt, concrete, packed dirt, loose rock, grass, etc. No complaints.
Razor 200x50 Tire & Inner Tube Set (e100/e200/Dune Buggy/Epunk) https://www.amazon.com/dp/B0021XPF9U/ref=cm_sw_r_cp_tai_iM3sDbSN49WNB
Totally spot on with the Alibaba tires.
I’m at about 4k miles on these:
The harder ones usually are marked “NYLON” and initially look like cheap hard plastic until they’re broken in. These aren’t quite as soft as the true rubber ones but they last forever, and I ride through broken glass without pause. I have a set of each material type, same mold. The softer ones are at the same level of wear about 1k miles in.
@Shikaka I rock those exact tires when I want super grippy soft street slicks. They’re great and a lot of fun to carve hard on.
How much pressure do you guys run on these Ali tires? From my brief experience with pneumatics I know I like to run they really stiff
I use those off-road wheels on my board and they work great. They come will balanced from the factory and the tire itself lasts forever.
I run those Razor streets at like 45psi.
I run my Alibaba nylon knobbies at 50-60psi
You cray cray
Dual 80100 motors need alllllot of contact with the ground. Im running 12s10p 130kv motors on a 1:4 gearing ratio. I had to use enourmous sprockets just to handle the power.
Thanks @Venom121212, just placed a order for the nylon ali’s
Can you do us a favor and post pictures when you receive them?
Often the pictures don’t match the product exactly, just curious.
certainly, however there are a few photos allready posted above by @DerelictRobot but his has 4,000 miles on them. I’ll post what freshies look like in about a month once they arrive
Yeah but that guy is a total knob and can’t be trusted.
@Venom121212 @DerelictRobot what do you guys use for pulleys and mounting these?? Very interested in trying out a set
I don’t know anyone that uses those aliexpress wheel hubs, just the tires and tubes. They fit all normal mtb wheel hubs commonly used here though (mbs and tramps hubs that fit their 8" wheels for sure)
All gear drives over here.
Has anyone tried these tires and hubs what are your thoughts on both
Yes, they work well. There’s an entire thread on the other site dedicated to this but long story short, you’ll need to print some custom pulleys but it works.
