Does anyone knows a Aliexpress source for 10mm*90-100mm Shoulder bolts?
The only I could find where as pricey as from Surfrodz themselves.
I ended up getting them locally, is that an option for you?
I should have bought some for you
Read the discussion here…
McMaster Carr carries good shit
Thank you for this post! I just picked up these
And need to replace a shoulder bolt if I can get the stuck one out.
Be careful of stuck bolts. It’s usually either a heli-coil problem or trash in the axle shaft. Either one will strip the threads of the hanger if you try to twist it too much without using a gear puller at the same time.
I think his treads already went to shit according to what we were talking about last night
I might have already done that. I’m gonna try later this afternoon w heat and proper tools
We shall see!
The only vendors I found locally are selling them in huge quantities sadly.
@moon
I want to try different lengths anyway, your pulleys and mounts are beautiful thanks for the good work!
@mmaner
I read your write up and contacted the company already, they are willing to ship internationally, since China is closer to me I was hoping for that option.
Thanks for the write up!
They are only selling to businesses not to plebs.
But I found them locally on Rakuten for a better price then Ali.
I took them to a tire shop. Bolt is trashed but the truck is fine.
