ACEDECK ARES X1 - 14S4P 4WD TKP
Bro don’t try and pm me and justify false advertising because someone else does it. If you think it is okay for a company to lie and mislead its customers say it publicly lol.
Speaking of false adverts.
Okay I just got my custom n1 nomad and have the same thing it’s like the PPM ramping is too much after 36-37kph to go to 40-41 nearly throws me off I found a back menu on the remote by pressing 8 times and there I tried to make the s+ mode acceleration weaker from 40 to 35 - will try 30.
That does make it smoother because the push jerkiness of the board is lessened however the trigger is exactly at the same speed there’s like a speed thresholds that this board is smooth and then the last 15kph I assume are rough
fixed - there was a custom setting after hitting the button 8 times that tweaks accelation from 1-100% and it was set at 80 stock
i know its a old tread but , that why i see 2wd on my Nyx z3 remote ? interesting… if its possible to upgrade 4wd like will be great to have this feature to switch between mode , can someone help with that , i don’t find any information regards my remote programation or esc
Not sure but would reach out to Acedeck support. They’ve been pretty good from what I’ve seen.
they discourage me to do it , :rofl: and no information how to hook 2 esc
i told them i build own board since 2017 so its not problem for me to do it , so what am gonna do is to buy another geadrive and 2x 150kv motor paired with 2 vesc spintend or (flipsky ft85d if i can found out how to use them in 4wd configuration )
