New Metr log with 12S 6Ah 75C :
It’s quite cold outside but motors weren’t hot.
Lipos were hotter.
I don’t think FSESC 6.6 Dual is bad.
Lipos were hotter.
No, it isn’t indeed. I like it too.
Fixed that for ya ![]()
I’m the lucky one ![]()
One might think that the 80100 motors would run cooler than 63xx sizes due to lots of extra copper and normally not that big of a difference in current going through. I have experienced that the 80100 motors does in fact get hotter then any 6374-6384 motors that I’ve used on my trampa boards. Not sure why but they tend to get very hot during normal road riding, they do have a big bearing around the rotor that should create more friction and may contribute to heat building. Doesn’t feel like that should add significantly though.
When it comes to torque there’s a difference for sure, board just goes zooom with the 80100’s. At the cost of higher energy consumption and more weight. For most people I wouldn’t say they are worth it.
I would say that’s the reason why they also get hotter. At the same kV (like 63xx motors) the wire size for the windings are same diameter.
More energy consumption = higher current through the wires = more heat created.
That’s how I would explain it myself but I might be wrong.
At the same current they should run colder indeed.
Going with Trampa VESC 6 just to update my findings!
4 legendary trampa vesc 6 originals? You must have dropped a lot of cash
Some $$$ more or less on that build really doesn’t matter much anymore.![]()
1 grand for esc’s lol, crazy
Still cheaper than spending 600$ for Flipsky escs and than another 1k for the real deal some weeks after
I got two but don’t know if I’m going to use them any time soon. You know my habits of selling everything I get my hands on lol
I’ve got focboxes for sale
Four are 665USD + import tax.
This build is so expensive that there is no reason for me to cheap out a few hundred
Bucks… get the real deal or nothing
@Chibatterysystems are you planning to run them at the max 120 amp motor current or are you going to use the no_limits firmware and run more?
I will be running stock fw. 120 motor amps x4 is more then enough to kill me
Same here lol
