im Organized at work, but I’m here bc I don’t really give a fuck, thank you. I’m not an engineer. Sorry I’m sloppy.
There are no real plans, just fits and spurts of building, then riding, than wanting more.
I am putting 8 motor on a board even if it is really stupid.
I promise I won’t edit it this first post again.
So the question is do you want 8 wheel? If you get a CNC plate and put 2 motor mounts on it and a pivot in the middle you could have 4 wheels per truck…and it should ride silky smooth
Could you maybe get a “sponsorship” from a vender that could supply four drive gears and 8 pinion gears?
Then make a custom gearbox case?
Just to avoid that silly belt.
This though. .
oh wait I see that you are actually using two normal mounts together to avoid any major manufacturing.
That’s smart I see how this could happen. also damn that gearing
…but does @anon86070286 know?
Fosterqc:
Ultimate goal, yes, but belts for initial kicks.
Not in the picture. Hence a build to keep me occupied
Ah fuck, sorry dude, wondered what happened to her name!
Please provide crude render
Fuck yeah!!!
Do it! Do it! DO IT!
Where is the dual motor single wheel on that render?
Motors and a @Psychotiller mount that happens to work easy for layout and pre-helical gear testing phase.
I am going to use @kaly hellcat wides. Already ordered.
Limite production.
Precision CNC carved from Aluminum 7075-T6, these hubs are made for 200 x 75 Phatty tires.
We have put the best technology on these bad boys, our HANDSHAKE clamping system provides best rigidity on an eSk8 hub and the double...
Price: USD 60
I already have some rubber ideas.
I have a power source(s).
Not sure about trucks ATM.
That is solidworks launching hahah
*render provided Areovelo
I see why you asked him for one, drawing this is not as simple as I was thinking
was wondering about this, also what wheels?
If bioboards can break your proposed speed, why go though all the work.
Didn’t they claim 100mph
@Janux-esk8 already made a mock up of plates. Printed them and installed hardware.
Not sure I want to blow his spot up just yet.
I don’t know if I want a tight v or wide v.
“V” reference:
