Im looking fora pair of sensored maybe battle hardened 80 100’s or there abouts. Building a mountainbeast board
bruh my N5065 motor can take me up vertically are you towing a car with your board
Easy tiger.
Compensating for something?
Lol kidding. Just get some flipsky 6384s. Cheap and pretty good.
My bro is a hefty guy. He is paying. I am building.
What about more smaller motors?
???$$$ for them flipsky’s?
Gear ratio, motor KV and tire size all play a part in this too. What specs are those, you might be able to solve this with a pulley change.
I think they’re $100 each. For 6384 that’s pretty good.
A 4 wheel drive? Hmmmm how do i connect all 4 motors?
You’d have to use CAN or split PWM with another pair of ESCs
So 4 esc’s in all. 2 duals wouldn’t do it?
Personally don’t think anything longer than 74 is a good idea for 63mm diameter.
If you need bigger i think you are on the right track with 80mm diameter motors, just make sure you got beefy mounts
They usually say a picture is worth a thousand words, yet this doesn’t give us any useful info.
Once again, people need to know motor kv, battery s count, gear ratio and tire size before they can give informed recommendations.
4 singles or 2 duals would work
#sendit
12s 4 and or 5p 6374 192kv unity not sure on the pulley count. That’s why the picture those are 200x50’s
Id go bigger on the battery if needed.
