Designed to work with Twistar, Rockstar Pro, Rockstar (that I know, likely will fit most) and takes 50-70mm bolts and m4 lock nuts fit into the spaces on the gear.
Depending on your setup and tire size you’ll likely want the 5mm standoff - its in the file on thingiverse.
Didn’t realize there was a section for that, I’ll do that… have a few more I am going to upload as well when I get time.
Not modular (with the extent of +/- the width of the teeth) but I have a few more designs - I did each to be used with PLA so each one had a number of revisions along the way.
