Planning a new build with 12s3p/4p 40T and dual 6384s. Im stuck between the flipsky 6.6+ and the Lacroix Stormcore 60D. The Flipsky would be a hell of a lot cheaper but I’ve heard very mixed reviews for them. The Stormcore I’ve heard should be very good but I havent found any reviews on it at all. If I run between 50-60a, should I be fine with the flipsky? Or would it be worth it to upgrade to the Stormcore?
i’m pretty sure they are better quality and cheaper
plus you’ll most likely have almost all the Amps potential for the 6384’s (don’t go over 70 amps continuous on the 6.6+ it’ll heat up real fast and burn/kill itself down)
Dunno about the fsesc 6.6 plus but i have the older fsesc 6.6 which is rather big compared to the newer ones.
I think it is indeed hit or miss. I personally didn’t have issues on my 12s6p 30q mountainboard with 50 bat max per side and 80 motor max/ motor. But the Fsesc 6.6 was not enclosed.
Lately i used it (in an enclosure without any cooling) on a 10s4p build , impossible to pass sensor detection, tried it sensorless and had cutouts when going full speed on minor hills, …thats the kind of shit you get with Flipsky, it’s hit or miss, sometimes it works sometimes it doesn’t.
I would go Maker X DV6 if your tight on the budget or Stormcore if you have the monnies.
i get that. im just wondering why its not a solid alternative? lots of complaints about the 6.6+. this seems like a decent alternative. trolling for feedback.
DHL says that Spinted should be at my place tomorrow, so I’ll be able to test it in the next weeks, I have also received 2x ZESC units today, and boy those look amazing…
When you think that a couple of months ago there were none decent ESCs on the market other than Trampa… Then neoBOX fiasco, I am glad we have options nowdays… Torqueboards is around the corner of releasing their version soon…
