So how many of you have TB refunded for the TB40…
I’ve made the order on May 2 2020 and today I asked for an update on my order and Boom refunded…
Told me that they out of stock now…
Crazy that its been this long…
Oyea I’ve only emailed twice about the order.
I’m so upset that this was done…but I guess it is what it is
I usually just roll the sides of.my inserts in my respective glue and none gets on the bottom hole during “insertion” haha that spunds funny #butreally
That really sucks
F
@BadBiggz We should have more but it’s quite a bit ways out. If you haven’t found anything by then. You can reach out and we can offer it to you.
at first I was thinking it was just the way that dex’s order fulfillment worked, but with the TB40s its possible some of the pre ordered decks ‘had’ to be sent to people who’s decks got cracked in shipment. Doesn’t make sense to me if stock was so small on those why dex sold some to people after they arrived stateside/people with no pre order.
Is there an enclosure hole diagram for this @torqueboards? Designing a custom enclosure with only my shitty calipers and want to make sure my measurements are accurate
This was still not enough clearance to get the motors far enough off the ground without hitting the deck.
@Boardnamics I would pay greater than $10 more for some mounts that were 10mm longer
Yeah you have to almost match the back surface of the rear truck to make it work.
We should have some longer reverse mounts soon that will clear even a 25D baseplate.
And they’re thiiiicccc and pretty ^^^
@jkoljo the 270s interfere more on the side of the tail, the motor can is still not higher than the hanger but it’s closer.
Oh, the new thicker mounts are also longer ? That’s great, when do you expect to sell them ?
done cuttin.
I think I will just seal it with glue lightly and hope for the best.
@Edratuom Should be about 15-20 days or so.
@torqueboards can we get a sneak peek pictures or design
In esk8, all parts are perpetually 15-20 days away
When will you have some more TB40 decks in stock?
DS Enclosure in the works yet?
