MR60 Aren’t waterproof by nature but there’s never been a problem with these on this board and they have done a lot of miles in a lot of different conditions.
@Kug3lis @3DServisas
Can you guys make some of these again
I really need a set of 48t kegel for my new 6x2ish wheels
I asked recently as well. No dice
If they aren’t worth the time to make, then they should raise the price a little bit, THEN make some more.
If they get any more expensive then there will be no point and everyone will just switch to gears
plastic gears? Some folks don’t use belts because of cost. They use them because they’re the thing that’s desired for what they want to build.
Hmm, POM wheel pulleys might be a good idea to save cost!
Have you guys tried boardnamics press fit pulleys?
Edited after being flagged
I have, and they’re good. But they don’t go up to 48T like 3d servisas ones do
Did.
What size bearings and spacers come with the FatBoy Solid Core Hub 3.75?
What is the length of the spacer?
Edit:
Got a response:
“6001 bearings with dimensions of 28x12x8. Bearing spacing is identical to Superstar rims.”
I think that means the spacers are 12x16x17.8?
Why have pulleys on your site if your not going to make or stock them?
I asked that recently as well. No response
Interested!
In fact, even bigger might even be better if that’s possible?
Sorry guys, but at the moment, I have big backlog of orders for gear drives, and I dont have free time to make pulleys, I am not sure then I will be able to make them, but when I am free up my backlog I am going to make them.
i need to remove the motor pulley from the bearing (got a new bearing) wondering how i can do this?
thanks
You need a bearing press or something similar
i got a bearing puller
is it just pull on the motor pulley while having the bearing clamped down?
Yea
cheers got it off
to put it in the new bearing it needs to be loctited? or just press fit
