yep i can see he drowns his stuff in it
i thought audris put them on though as i know he set the backlash and stuff
still not sure where i am meant to be pulling from
He sets the back lash, but you put the motors on yourself. Donât need to remove pinion gear to add motors. It is best to pull on the pulley itself. The housing holding the pulley is alluminum and with enough force it will slide off over the pulley. So you may need to get that sucker almost red hot because of how much loctite is on it
k bit confused
so am i trying to pull the puller itself or the metal piece underneath
Look at it as trying to push the motor out of the pinion, not pulling the pinion off.
ah ok so i dont wanna grip on the pinion i wanna grip the sides of the aluminium thing?
Yeah, youâre getting there
awesome
thanks
got it off and inot the motor
not directly related to 3ds stuff but anyone know now how i take a bioboards motor apart (thing is super sealed)
could be it needs to be completely replaced but not 100% certain
I did an assembly guide that can also be used to guess how to disassemble, but itâs not for those motors with a rotor skirt bearing like you have there.
A crude technique that worked for me was to screw a bolt into one of the mounting holes youâve exposed there beneath the faceplate, grab onto it with some mole grips and then pull it and the can apart sharply.
Once youâve done that, pull that outer bearing off, throw it in the fire and replace it with something that wonât seize up when it encounters moisture.
cheers man will try to
I noticed a odd sound while out riding so went home and pulled one drive appart and noticed this.
@3DServisas what can I use to get of the grease without weakening the plastic? I usually use âsmall parts cleanerâ or CRC quickleen but not to sure about using them on plastic.
This doesnât look like any damage really, just wear caused by some particles maybe. What sort is the odd sound?
Also regular industrial paper towel is enough to clean it up.
jupp looks like something got in the drive. There are small shavings missing just like you carved out a little piece.
Hard to explain the sound but itâs like there is something in one teeth so you hear it one time every rotation of the wheel (so the noise is in the big gear). All covered in grease so cant really inspect the gear good enough.
EDIT: to answer myself the small parts cleaner detergent should be safe on POM after checking out what it contains.
Check if maybe you got something stuck in your big gear. The small wear scars will have no impact on overall function. Neither the sound.
This is not POM. Just FYI.
Should also be safe on oil filled Nylon but I agree a paper towel is sufficient.
Personally have no idea what the material is, itâs hard and oily though⌠All I know that I am bashing all three sets of gear drives I have and never seen any signs of wear. Just maybe the same small scars from getting dirt inside, though, changes nothing.
Break cleaner FTW
Or if your really carefull, just use dish soap
Wouldnât brake cleaner melt the plastic?
Some plastics sure, I cleaned my yellow gears like 10 times with gasoline, nitro, and break cleaner, and they are still pushing me around, these seem like chemically resistant. Not ideal for sure, but gets the work done fast.
I guess itâs all a material science thing, Iâm not super familiar with which solvents affect which types of plastic
