I use wedges buts that to get the angle of the mount and motor where i want it, doesnât add much height at all. For the spacing I use aluminum spacers, I think 15mm is the correct length.
13mm of risers and a caliber baseplate on the top vs adjustable baseplate on the bottom.
For that you will need spacers. Either get some from a skate shop, or just put quite a lot of speed rings. PLA spacers are fine and all, until your bearings heat up for some reason.
EDIT: you can also take apart some 608 bearings to get âfreeâ 7mm spacers.
Hummie did need a tiny bit of tough love, the cutout was just a tiiiiny bit too small, and skewed on one side of the deck⌠To make it fit just used a flat piece of iron and 60 grit sandpaper, 15 minutes and itâs in.
Also wanted to say that i received my package too. Used standard Lithuanian post, ordered on the 19th of April and got them yesterday. The quality is fucking amazing. Canât share pics since my who build is going to be a surprise
