It’s a pressfit with a flange seat for a third bearing.
Hub bearings with standard spacer and custom third bearing spacer
Pressfit with third bearing
22mm bearing seat with lip to prevent third bearing from slipping thru
Those don’t look like burrs they look like machining marks
Machining marks result from deficiencies in the gear manufacturing process, such as:
Whos not a vendor?
Ur mum
No, but in all seriousness, he’s a manufacturer that sells his stuff, not a reseller (that is typically called a vendor, others do their dirtywork).
WHO?
3DServisas, obviously. Everybody thinks it’s a huge team of people somehow.
That’s stupid. He’s a vendor. Dosen’t matter if it’s 20 people or one.
He has a site with parts for sale that he designed and puts his name on.
Allrighty. I stand corrected.
Dem pulleys tho.
More detailed:
This means: you have pins that are max 9mm into the wheel. I don’t think I need to explain that you need to tension the belts.
What happens when you tension the belt with such low contact? The pulley skews and you get a wobbly wheel.
I understand that people love to see shiny things in pictures but this is “design” for you.
Let’s talk about dem pulleys.
3D Servisas pulleys are best ones I’ve ever used. Yeah, they look good, they work great, they fit very well, they last a long, long time, and they are high-quality.
Those of you who value those things should probably jump into this while you can.
Where is the kegel pulley that has a pin every hole?
Still sleepy, sorry. Corrected. Generally it means that this one of Janux has too low engagement to keep solid alignment of the pulley.
Ok that makes more sense. I’m still.confused how he to few pins. There are 10 holes on kegels and he has 5pins(every other). They do look short though.
With every-second hole you need perfect pin thickness and length to have a tight fit and a smooth roll.
3DServisas has this, effort was put into making them fit like a glove. This means a bit higher pricing, but better quality of life.
His are every hole, and even has a separate version for reversed wheels, where pin diameter differs slightly.
Agreed, those look like the nicest kegel pulleys out there.
The Walmart pulleys are the exact same:drooling_face:
