Hmm. What’s the part?
If @Skunk wants I can add a few layers of epoxy for strength.
Go for it. Im gonna grind it into dust at some point
What printer do you have?
I need someone to design and print a holder for both a loopkey xt90 and an xt60 connector in this hole here for a hummie deck. I would like to mount it with screws or perhaps glue on the bottom of the deck.
Can anyone help with that?
its a tensioner for a belt that break a lot in an analytical instrument the area that breaks off is the hook.
Seems like you could model it pretty easy without a scanner
Well it isn’t flat it has stand 2 stand offs one is the metal piece the other is the hole on the right. The little piece that is coming off the back has a little tab that stick up for a spring to to sit on. Without having any knowledge of making the 3D models I wouldn’t know where to start. That tiny piece of plastic is a $270ish part.
@Skunk Print finished should I print the xt90 Holder
Do you have dimensions for it?
And more pictures of it?
I can get more pictures and dimensions
If you wanna print this too that would be awesome.
Im gonna hold off on the little loopkey handle. Think im gonna make something a bit more custom.
Thanks again man, really appreciate it.
Yep no problem.
Take the picture of it, and import it as a layer into fusion. From there you can trace it with arcs and a make a sketch pretty easily.
Thats what Im planing on doing, it is a really complex part to design though
I’d like to have this one printed, if anyone is up for it. I’m in Nashville. Let me know your fee.
I can print you one I will pm u when school is over
Ultimaker S5 bro
Have a 3D printer and located in the Vancouver wa area.
