Hello
After 3 printers that worked poorly I decided to build my own Im copying a really good design but all the connections are 3d printed so I’m making it up as I go along
Not sure what to do about the hot end how to attach it to belt on x axis and cool it any ideas? also what length screws are best I’m building it with 2040 extrusions I have m5 nuts
Wonder if someone in the uk could help me out with a few prints please building a printer which I’m struggling to copy need these special brackets to finish it would sure appreciate it will obviously pay of course.
Can anyone explain what’s going on here? Just installed Microswiss hotend and direct drive on the Ender 3.
Aside from retraction settings (1.5mm distance, 35mm/s speed)
What’s your print speed/acceleration? It kinda looks like ringing, where there’s excess inertia from the print head moving around. Direct drive adds quite a bit of weight to the moving head, so my guess is that extra inertia’s causing a bit of overtravel.
I was narrowing it down to 2 possibilities. Print speed and underextrusion.
It was printed at 60mm/s so I lowered it and it’s still seeing the issue so now I’m moving onto underextrusion.
I was pretty certain I set the esteps properly. I measured out 10mm of filament, told it to extrude 10mm but I ultimately had to set esteps to 135steps/mm
Maybe clogged nozzle…?
Oh damn @mishrasubhransu overextruding? Okay, I’ll try that after this next test print.
10mm is way too short to give you the accuracy you need, IMO.
I’d suggest trying that again, but with 100-200mm of filament, to give you more accurate measurements.
(A 1mm measurement error on 10mm is 10%, whereas the same 1mm error in 100mm is only 1% - ten times more accurate.)
