Curious about that, could a geared pivot help in making a leaning board with turning wheels while killing wobble?
Like a car direction column but for skateboard.
I hope you donât mean actual toothed gears but yes by adjusting the geometry you can change most of the turning characteristics.
Oh you do mean a gearbox lol
@starky_boi I would bet the lean board was some inspiration to him.
Yes like really a toothed pivot or column, basically something which would not kill the lean we love but bring snap carving and maximize grip.
Wait are you talking about Ackerman steering?
Where the inside wheel steers greater than the outside one to accomplish tight cornering.
That would require some significant effort but itâs possible I guess.
No I was wrong thatâs not what you were talking about
You are giving me a funny idea of like an oval shaped gearbox that has variable turning amounts from level to full carve. Could be disastrous at speed maybe
Thatâs actually a new concept for me! I knew about pinch of wheels for reactive changes (open) or steady straight (negative) but didnât think it would in fact affect the corner itselfâŠ
It wad indeed ![]()
Somehow, I quickly envisioned this after your ideas and mines lol
Here is what I got with âmyâ trucks geometry
The wheels are somehow moving right but they stay straight
Any MIT engineer wanna help?
I know I could try to replicate the LEAN BOARDs trucks but Maybe thereâs an easy solution to my problem
New design, inspired by the @RipTideSports thread about âchannel trucks bracketsâ
Cheers,
D.
4wd hub motor channel trucks
Is that a hinge?
Yep, but a super-strong one of course ![]()
I LIKE THAT @DavidF, can you post on the bracket thread to stimulate other ideas of where this can go? !!!
PMâd you
I know the upper spring is suppose to be a strut/tensioner but I can also see this as suspension too now
It was indeed introduced as a tensioner and suspension!
It may be a little small for this use though
Hey I love your new version! Glad to see it receives better input than in the French forum too
Do you think you can make a version adapted to regular decks? Top mount and drop through for example with customizable angle baseplate.
I imagine a Jet type deck with this under. Silver surfer vibes right there.
Sure I shouldnât be too complicate
Let me try with my 3d scanned switchblade
40"?
