Working on a new model, people can customize the look, by change the rim cover.
Here the rim model for street board, fit 8mm and 10mm axles, offering 47 and 66t pulleys.
*290 gram per rim(included bearings, screws)
*48mm width
*Negative offset rim design
*Oil slick look
- Rims and pulley CNCed by 6061-t6 aluminum
Use code NBEL10 for 10% discount
link: www.newbee.store
Beautiful man.
New hub would be 65mm wide, also we changed the inner diameter of tyre seat, from 91mm to 94mm for better wheel balances.
We’ll keep the rounded lip design, we realized the rounded lip can fit 9 inch too, and balance good.
Will the Pentagrams be back in stock soon? The new ones look great but i prefer the pentagrams
Yeah. The pentagram look will be back soon, also we will offer a another new look too, they share the same inner halves.
Any plans to size up the bearing seats a hair too? Ive heard of a few that needed heat to get them in.
Will do, we will Re-CNC the bearing seat.
does a standard bearing spacer work with the hubs?
Somewhere around 22.30mm Length?
I believe bearing spacers help with side loads that happen from sliding,drifting, etc.
Dunno but the boardnamics ones for Rockstar II were exactly the same height when I checked
We’re waiting the sample to be done atm, unfortunately the new factory can’t do oil slick plating.
Sample is done, production batch will be available 3 weeks later, stay tuned! Available black, Red and Blue.
Darn, no green?
Green > All
What color are the wheels in the picture then? I guess it could be black if the studio lights are so powerful, but that silver / grey looks sick!
Will you be offering pulleys to match as well???
The hubs are the same as MBS rockstar hubs in terms of bolt pattern, so if they don’t offer them, you have an alternative place to get pulleys from. Some folks on here make them
Just to confirm, pattern is the same as MBS RSII’s so there wouldn’t be an issue putting these on BN GD’s right?
