Me too! Fivestars are awesome
I jumped on them when I saw they were getting them in black.
perfect ! motors feet without any extension ?
you sold out???
also any update on the helicals
Probably because more inferior plastic is used no?
That’s a rockstar hub so probably just the shape difference?
Are the others bigger? Because the rockstars look like they use glass filled nylon. The fivestars look fatter so if its the same dimensions it should be heavier. But if its lighter the glass fibre is prob taken out.
The fivestars are wider but the dish dips in compared to the rockstars face being flat. I’d still guess material differences or pigment usage is the main factor. That’s not a lot of volume difference.
Moon, displace water from a full glass by dropping each hub in and give us a volumetric analysis
The shaft needs to be cut, but otherwise the motors fit.
I don’t have these fivestars anymore
I wasn’t really that interested anyway
Your mom taught you to not lie! you know we both wanted to know this.
Im as sad as you are.
How is the pinion gear supposed to be fixed? In axial direction?
Im using 8mm shaft and keeway…
Green loctite of your choice
680 failed on me twice.
648 is holding strong still
648 loctite
LMAO
