for batch 4 it will be 30mm
WIP Motor adaptor for Lacroix motors:
Pinion engraving applies to straight cut and helical
WIP Truck clamp for Lacroix Hypertrucks:
WIP Adaptor for XCELL rims & MBS Rockstars, for Lacroix Hypertrucks:
Other WIPs
5.5/1 straight cut gearing
5.2/1 helical gearing
4.2/1 helical gearing
18" RKPs
when inrunner geardrives?
Merica!
I want to make bumper stickers for these things that say “being fat is the result of poor life choices, not a disability. Keep walking”
hmm tempting
I should add some more patterns on this thing if I can get them to fit. There are some nice motors out there with irregular bolting patterns
MBS or Trampa would work I guess.
Or the sunmate which I think is compatible with the Trampa pattern.
Yeah but once again
I have 2 drives both with berg pattern
Got 3d servisas and boardnamics
Might have to buy a moon drive and sell those
Is there enough room between the drives for something like 56123’s on moon san jose forklift carve trucks?
Ill have to ask Mr San Jose
One of the problems is that with gear drives the base plate is in the way and you need some extra length which would require reeeeally wide trucks or a very low mounting angle… probably…
San Jose in UK? Sounds like a sunny place
It’s the least stabby place in Britain.
Hey Man, happy Holiday. Glad you’re back
Thanks, Tama. HH to you as well.
I wouldn’t abbreviate that if I were you
is the wheel adapater a 2 part now? are their big pins that those big holes fit over?
or how’s it work with the XCELL rims?
is this only on the hypertrucks? or is the wheel adapter independent and will it work on the MBS trucks too?
does this work with the original axles? or require the longer axles that the lacroix gearboxes require?
good question, Ill see if thats possible as I didn’t think about that.
Works with original axles
Several ways you could design this but for ease of use Ill use pins. small ones
