Yes 5.2:1 is the right decision for you
I’m also a big fan of Ali 6x2 tires, does anyone tried it?
So since then I have not been really selling many Bergmeister setups, future batches will ditch all support for Bergmeisters
good riddance, 2.9" is stupid
Nooooooo
Would it be possible to keep a couple adapters spare just in case…
Or would we be able to get them made in the future?
Thanks
How many inches do you like…
Will they support kegel?
I will make you custom adapters if need be.
Got mine today, is there an assembly guide?
I don’t know if you already gave the information but when will be the next batch ? thanks
Early Jan
would it be helical ?
@moon what is the minimum axle length required for use in these drives?
Would a motor with a 10mm dia 24mm long shaft work?
That would be perfect actually. The max shaft length for this drive is 24mm, so you don’t need to cut the shafts.
@Grubzz eventually yes. More stuff will gradually come along whilst the new batch arrives
Seems the easiest solution (but maybe not the cheapest) is to use 6’’ tires which fit on 3.75 hubs.
There are a few.
29 mm on mine.
thanks!
Which hubs though
Have 2 sets of berg gear drives now so would have to change both those also
@haggyboard.timo needs to make some 3.75 inch hubs with berg mounting
