Done, thank you
Super quick render to check mount clearance on boardnamics 220mm hanger and 6380 motors
It wont work, need to go wider.
will 6375’s work? I assume 6355’s fit…
Ill check later
Top tip: use 2 pinions in and upgrade to a Lycan drive
Yes
80mm would fit if the hanger was like 5mm wider. Theres 160mm between the 2 plates
I got the axle length wrong in the first model. This is an accurate representation of what things look like inside
I ordered a set of your trucks to play with!
@moon do i need a 2nd set of adapter plates to use with these trucks, or are the adapter plates universal like the wheel plates? If so, can you please PM me and let me know how much more $$ to send you?
Lycan drive?
I know you’re half kidding, but More info please if this is a real thing. lolol
edit: Found the other thread.
No AT/pneumatics, no care!
You’ll need additional clamps
When would this batch of drives be available!?
Like 6weeks
COUNT DOWN TIME!
you just have to pm him bruh to get on the list
On a serious note can people drop the 3gd stuff? I keep getting PMs asking for updates
Anyone else use these on surfrodz, with the clamp outside and running 100mm axles?
Not that I know of…
