If you are running 63mm motors you can run all the ratios
Will you be offering any of these steel gears near the 4:1 ratio?
yes
The wheel gear tooth count is still to be decided
why do steel gears need to be bigger then pom for the pinion gear
Different mod. Smaller teeth means more teeth needed to reach the same diameter.
Also means 10mm motor shaft available on short gearing, which is noice
@moon So I can run the 5.2 on steel in my v4 GD?
Yes
I will first release steel gears that fit in the older drives
Pumped man! So not only do I get a stronger gear but I get more torque too. It’s a win win!
The anodszing looks marvelous! Love the gunmetal on the hanger
Roughly how many days out until we can buy them?
Both look dope
Phew, I was just about to say I love that slate blue color and got worried.
Drives will be instock around 2nd week of April
Just wondering, what are some pros/cons of steel gears vs. POM? Only concern I have with steel is if GD comes loose somehow while riding the steel gears will stop you dead in your tracks whereas the POM will break and not throw you off your board. Thoughts??
You’ll get thrown off regardless ![]()
