They should work, you do need to cut the shaft of the motor to make it shorter. And the keyway cutout is shorter than the standard size. I believe it only fits a 8x3 mm keway, I cut down a 12 mm one. Plus you need to close the gap between the internal motor faceplate and the motor pinion with a brass collar/spacer, this keeps the motor can in place. The motors come with this collar, you just need to cut it to the right length to gap the space perfectly. So before you attach the motor pinion, line everything up and measure the distance. The brass collar also sits a little inside the faceplate so make sure you take that distance into account as well.
