Hi guys,
Today we want to introduce to our new member -MAXKGO BMS (referred as MKBMS)
First of all, we are frankly to tell you that MKBMS is developed based on BMS open source materials. Our engineers have made a new hardware design based on the combination of DieBieMS and ENNOID BMS open source materials. Here, a special thanks to the developers of the open source DieBieMS and ENNOID BMS.
In terms of hardware, we mainly made innovations in size, circuit layout and board. We designed the circuit layout to be more compact, so that the size of the BMS is more mini, only 109X40X20mm.
MKBMS have adopted automobile-grade locks and reverse bayonet, thus hard to loosen the wires. The PCB board is made of 6-layer*2OZ=12OZ copper thickness, which has better current flow capacity.
At the same time, we have added a 6063 aluminum alloy shell of which the surface is coated with black sandblasting oxidation, achieving the function of oxidation resistance and insulation.
MKBMS have overcharge protection, overcurrent protection, balance function, temperature protection, etc.
Support batteries: support almost all lithium batteries such as lithium ion batteries, lithium polymer batteries, and lithium phosphate batteries.
In order to facilitate everyone’s use and reduce shopping processes, our BMS board will be shipped with switches, display screens, USB and other wiring accessories. You can see the following picture or browse our website for more details.
MKBMS have these BMS specifications:
LV master board and slave board 12s, 18s. They are also shipped with switches, display screens, USB and other wiring accessories. Sure, there is also 24s all-in-one board. Besides, we plan to launch all-in-one BMS 12s at the end of November.
We will continue to improve BMS in the future and sincerely welcome your suggestions and ideas to make BMS better.
Last but not least, thanks again to BMS open source. We promise to pay $5 to ENNOID BMS open source for every piece of BMS sold. Thanks for your support.
Free shipping over $59 for most country. Hope you will like MKBMS! ![]()
