20SSS 2ST BRO : a 20S SSS inrunner 2Stage reduction build (2023 BOTY Candidate Update)
More pictures of these amazing E-TOXX STEALTH420 trucks, 2stage gear drives et wheels :
:sunglasses:
From Beauty Queen to Brico DépÎt :hugs:
Issue : moving gear tub cover
Solution :
Issue : torn insert
Solution :
what was the material?
sry to see it failed. keep pushign 2 stage reduction forward. so cool. :slight_smile:
It’s POM. E-TOXX white POM gears are harder than the black ones.
Jens has made an upgrade for his gear drive :
With clamp system, it shouldn’t move anymore!
Yet, Vic advised me to use Hex Cap Screws instead of Headless Setscrews with Hollow Heads and it worked better for him with classic system.
I’d prefer straight cut gears to helical cut gears, because axial forces create problems.
2nd stage sprocket moved on axle because of that, in spite of Loctite 648 and key. Maybe I didn’t put enough Loctite here. There was enough yet to make the sprocket very difficult to remove even with a lot of heat.
This sprocket has eaten the aluminium housing on its side, making deadly POM/aluminium abrasive powder.
So it was a 2 stage killing of that POM gear. First shift of the sprocket, and it survived, and second shift of the housing on the hanger, which finally finished it.
Next step is adding these on motors because I feel concerned about how hot they get now in summer, without any temperature monitoring because there is no built in temperature sensor.
We would cook these SSS with current at 8s. Would watch em with a temp gun.
At 20s u may be finding iron losses. But they are only 6 pole so maybe not. Maybe just current.
Redbeard torgo, lighter rider did well with them watching temps. And the cheap fans helped. I believe @davidbonde is still using the SSS as well and not killing them.
I moved up to the castle 2028s. Then the hobbywing 70125. But I think going higher kv would handle more watts better but needs more reduction
I think there’s more power for us in esk8 at higher kv / rpms with better reduction.
So you’re saying helicals killed the gear. :grinning: :stuck_out_tongue_winking_eye:
I went from not killing them to kill five in a short while. Have moved to 70125 now.
Actually temperature of the motors is not that bad! I thought they were hotter because I can not touch them for more than 5 seconds.
But with a temp gun I took with me while riding, it didn’t go further than 65°C! The weather has been very hot today. Exterior black plastic parts of my car windows were 74°C.
So I may not have to use those fans. Maybe heatsinks of light colors like than would be just ok :
But I can’t find the good dimensions.
:heart:
most of those fans are pretty low qual.
I wish i could find some picks of @computers custom heat sinks he did a couple years ago. they were like 3 big shark fins comming off the thing. he made 'em with his CNC.
but if you don’t need fans or heat sinks, that’s nicer.
IR temp guns often read very low on shiny surfaces no matter how closely i hold sensor to surface.
My oxidized aluminum top radiator tank likes to show 126f at full temperature, but a Ktype thermocouple in contact with it will read 185 to 195f, as expected.
A piece of black Gaffer’s tape will read 185 to 195f, but the shiny aluminum an inch away, 125 to 135f.
My flat black hub motors will read 137f, ang i can keep my fingers on them for a longvwhile, but my natural aluminum finned heat sink reads 105f, but my fingers on it sense hotter temps than the hub motor caps.
As far as powerful small axial fans go, look into Delta, they have some scary high rpm 5-48vdc models available, and their pressure and velocity is impressive.
Loud as F though.
yeah, It’s IR based. so light reflective reads more poorly than light absorbing. I think i read that in the manual for my temp gun. I think on the black motors it could be a decent read.
that said
 you can guess at the delta by, as you mentioned, putting some more matt black tape on the motor and measuring that bit to compare.
in any event. our IR temp gun measurement of 65c was considered decent on those SSS motors. 71c and up we would let them cool.
my set of 56123 230kv never exceed 57C at 200a per side on 12s. some thermal paste between the motor and mount should help, but any 56mm rc heat sink should work fine
You’re right I got mixed results pointing the laser at the can.
Yet, I point the laser here :
And confronted values with what I feel when I put a finger in hot water :
It doesn’t bear 60°C for more than few seconds.
New problem: following loosening of the rear truck screws and the lever arm induced by the width of the STEALTH420 hanger, the screw holes have widened. The rear truck moves with the vibrations and when empty the beast no longer moves straight.
I used the very precise E-TOXX baseplate, MILLIPUT two-part resin and the screws coated with lithium grease to rebuild the screw holes. I finished the holes with liquid epoxy passed through a cotton swab.
Now there is no more play with the screws. :partying_face:
This time, I was more rigorous applying LOCTITE 243
This is educational AF
I destroyed the screw on the STEALTH back truck on a turn.
The ENGINEER PZ-58 pliers were very useful for removing the end of the screw that was stuck in the base.
This screw is 10 mm in diameter and is class 10.9. I bought the same one again. I couldn’t find an equivalent in 12.9 with a countersunk head.
So, I don’t see what will prevent this situation from happening again. :sweat_smile:
wowwww cool to see this build is still kicking ass, what’s your long term verdict on the high voltage with those inrunners? what kinda range have you been getting long term?
This is by far the most powerful build I have. The Go-FOC D100S handles 20S batteries and 360kv inrunners very well, provided traction control is disabled. HFI works perfectly with phase filters off.
Consumption ranges from 33 to 40 Wh/km with this riding style :
https://www.instagram.com/p/DPM11ChDJHQ/?hl=en
The trucks are quite wide (42 cm), but you get used to it quickly to avoid hitting obstacles.
In the woods, I can make sharp turns while drifting with unlimited power thanks to the 2-stage gear drives.
I’m desperately trying to buy replacement gears from Jens at E-TOXX. When these fail, I’ll be stuck
 That’s really the problem with gear drives in my opinion: getting replacement parts.
I dream of metal, straight-cut gears. Helical ones add too much risk of failure.
Kingpins break not because of strength necessarily but because of fatigue accumulation. The only guaranteed way to prevent this is to swap them from time to time preemptively.
