These need the longer axles.
I’m using them on TB 218 trucks.
@rafaelinmissouri
Did you have to file them a little?
What belt width would you recommend with the pulley? I have 12mm currently
Oh. I did have to file. Not the length of the axle. But around the tip. For the inner diameter of the pulley
I prefer 15mm belts. But have not had issues running 12 in the past
I ordered these pulleys from @dickyho and received them yesterday. The transit time took longer than I would have liked, but that wasn’t dicky’s fault. The package was stuck in US customs for a few weeks.
I’ve used 4-5 different pulleys from a variety of other vendors. These pulleys are the easiest to install compared to anything I’ve used before. The tolerances are tight and everything comes together very smoothly. There is no slop in the connection between the wheel and pulley. Having the press-fit posts makes the alignment a breeze and the nylon sleeves allow the attachment bolts to fit very snug.
I highly recommend these pulleys for anyone with a kegel core. A few pics:
I want to get them too, but he doesnt respond to me
Did you try messaging him here? This is the best way to reach him right now.
Yes… @dickyho, I would like to buy some things from you
Send him a private message. I’m confident that he will respond. Just might take a few days with the time difference.
What’s the difference between these two retainers? Read dicky’s description, still not clear why one is better than other.
The bolt size is different, depending on the version.
From his post earlier:
- one is for 5mm bolts, for my current kegel pulleys.
- one is for 4mm bolts, for my new kegel pulleys. (will be for sell soon, the product have been very slow during the out break)
What’s the length of the M4 bolt that we should use with the Kegel retainers? I assume the tubing is 5mm OD 4mm ID?
use m4x50 bolts
Do you have 32T kegel pulley dickyho ?
no, i dont have 32t
@dickyho I need some more mounts your email store is still down can I order direct?
Message him directly.
Dicky, do you have the 44t abec pulley available?
Bump for @dickyho coming through once again. Good parts, well packaged with attention to detail on a complex order. Excellent communication too! I felt like a kid at Christmas opening this present.
[end of commercial]
Yup, great seller.
